That stalks in the video I posted seemed hard as marble so I believe it.I've seen a number of expensive katanas and dos manos swords snap on bamboo. Beware.
Great one! Ball in a cage could be pretty tricky.How about a Case peanut with CV steel. See how long it takes to whittle through a stalk.
No I don't, I laugh at people that buy high performance metallurgy just so they can say they bought it. Not unlike people that spend big money to go to significant sites to get a selfie just to get a selfie at a significant sight.
The word geek was too generous because geeks actually study and appreciate technical achievement.
Anyhoo, last I feed the trolls, they will have to seek attention elsewhere. The block function is a beautiful thing.
Move to W&C in 3...2...1...Come on man, you can't afford a blade made out of any super steel, stop fronting.
Green bamboo is a great medium for test cutting have fun and be careful
Ice Block Chop or nothing for me.It's my #1 favorite blade target. Fresh, hard green bamboo.
Poor example of bamboo VS blade, but here's that straight sword I showed you at Blade Show a few years back!
Adios FreonHow about prying the ice out of one of the freezers at the lab?
I'm familiar with the typical cane knife. The shape I posted, although not the common standard, is not "very atypical".That is a very atypical shape for a cane knife.
Typically a cane knife is lopped off at the tip end effectively square and without a cutting edge and with a hook on the non blade side to gather the cane sticks
I've been around when that happened. Definitely an open windows and evacuate moment.Adios Freon
That sword annihilated the bamboo. Good job.
It worked pretty well, but was far from ideal. The straight blade was so narrow it was almost like cutting with half of a rapier.
I don't quite understand the physics of narrow blades in terms of cutting if you mean the distance from the spine to the edge.
I get a thick blade has to be wider to get less thickness behind the edge. For example a lot of historical swords like the Chinese war swords are extremely wide. To me this is a reflection on poor steels back then having less strength. You can have a thinner and narrower blade using modern high performance steel that should on my mind cut just as good as a low performance steel that is made into a very wide blade.
Why should a wide blade cut better other than thickness behind the edge due to geometry.
