True that. I've spent several evenings searching various threads here and elsewhere looking for anything related to the 300 Series. Copied & pasted dozens of pages of the database and many of 300's posts as well, but as far as the differences between the SC & CC versions are concerned it is hard to distinguish from the database. There are various post & pics from various users that point out the differences, but it can get pretty confusing. As always on most of those threads it was usually 300 who set the record straight. I've tried to keep up, but it's like studying physics sometimes, and my memory just isn't what it used to be.Lol the good thing is one of us is correct and the other will learn something so I'd say it's a win win! And I admit it's a good chance it will be me doing the learning.
Clay
Version 1 of Model 303 as built by Schrade will not have BUCK stamped on back of secondary blades, Version 2 will have BUCK clearly stamped on the back of both secondary blades. I will seek photos. 300
That's OK my Photobucket account I have pulled my hair out and now have to wear a hat to keep from getting frostbite by recent weather..300
Here is a 301 with the secondary blades stamped "BUCK", but if you look you might notice a slight problem.
Bert
I thought the secondary's were always stamped on the pile ( reverse) side?
Never say never and never say always, and don't ask me how this happened. Sometimes it's fun to have an oddball.
Bert
I'll try this again....
I look for the 2 easier signs first; visible pivot pins = Camillus and large spey blade = Schrader (top).
Beyond that, there are other things not mentioned that are true in all of my examples.
Top is a Schrade and bottom is similar configuration Camillus.
All of my Shcrade 303s have less hump or belly on the handle (top in photo).
Also, I don't know if it's true in all cases, but all of my Schrade 303s have stainless springs where all of my Camillus and early Buck 303s have carbon steel springs.
Again, Schrade on top.
Another difference I found in my examples is the spacer in the blade channel. Notice the difference in shape between the Schrade (top) and Camillus.
Bert
No boxed ears, I will be wrong in future also, it is how we learn. Always check for clip blade swedge and/or Buck on secondary blade backs. After that we can debate the rivet heads. Remember those knives were hand assembled back in the late 60's and early 70's when hand assembly ment they assembled and polished the rivets as they saw fit. Some days more and some days less.........one of the reasons lot of companies quit using rivets. On modern 300 rivets are put on and spread from the inside liner before assembly. The most uncommon common mistake is a high head.... 300
