Try firing it indoors without ear protection. It is quite loud compared to a .32 ACP.
I know it is loud. I know it is louder indoors than outdoors. I personally will not rely on a "loud noise" to end a confrontation.
A .22 magnum firing a +P TNT round at over 1000 fps will transfer 100% of its energy into the target upon penetration and subsequent fragmentation. It is likely to do more damage and result in more shock than a single round of 9mm FMJ (which would likely overpenetrate with minimal deformation).
Actually, according to the NAA site, the Mini-Master will launch that tiny 30 grain bullet at about 1400 fps average. That puts the foot pounds at about 130 presuming you shot him at the end of your muzzle. (if we use your 1000 fps, you'd only have about 66 ft lbs of energy)
The much trashed 9mm fmj at about 1150 fps puts out 367 ft lbs. The .22 magnum is only putting out 35% of that power.
But who purposely carries fmj? I'll go ahead and stick with your 9mm choice, but I'll substitute MY choice for ammo for that caliber: Corbon's 115 +P JHP @ 1350. This load cranks out 465 ft lbs. The feeble by comparison .22 mag is only 27% of that power.
I do not see how a tiny 30 grain bullet churning up a piddly 130 ft lbs will do more damage than either of the 9mm loads. Might the fmj fully perforate the target? Sure. He'll have two holes to bleed from. Might the tiny 30 grain be stopped by a belt buckle? Yup. 9mm wins this contest easily.
If you can stay calm enough to fire 5 rounds accurately, it should be enough to do the job in most realistic scenarios.
Define "accurately" for us, please. Also, please address the time element you ignored in your response. How FAST can you be accurate ? How FAST can you put 5 rds on target? How fast when those targets are moving?
The problem is, most people are incapable of such detachment. They have an immediate adrenal dump and start firing as soon as they clear leather -- and when they think their pistol jammed after the 2nd or 3rd shot they realize that the entire double-stack magazine is empty (and nearly every round missed its target).
Let me understand this......are you saying that someone (you, perhaps?) armed with a Mini-Master will NOT have an adrenalin dump, will be able to calmly crank off 5 fast, accurate rds and win the day while someone armed with a 9mm will fire wildly?
If the person is going to flip out, the gun they're holding will not matter. If they do NOT flip out, then the better gun (of these two) remains the 9mm. If you can outshoot someone using your Mini-Master against their 9mm, then you should REALLY trounce them using a 9mm yourself.
Keep in mind, I'm focusing on the defense application of the Mini-Master, not the "fun factor" of it, or the random chance to hit a cooperative near sighted squirrel to supplement the pot.
