Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
As far as lockup goes, where the lockbar is in relation to the tang of the blade, I've found that after doing a cleaning and reassembling the knife, that before I tighten down any of the screws, with the blade closed, I grip the scales so that I push the lock bar side towards the pivot, pressing against the solid side, sort of a side shift type thing, and while I'm pressing/pushing hard, I then tighten down the pivot screw and the rest of the screws. As I find that there is a minute amount of play in the screw holes and that little bit of pressing will change the lockup position back towards the outer edge.
I remember a LONG time ago there was talk that the sleeve on the stop pin was not concentric, meaning you could rotate it to a thicker area but that was speculation and turned out to be not the case at all.
G2
G2
