Wow, Sodak that is a very generous offer. I am not sure I can accept that (though it is very tempting).
Nah, they were on sale for around $8, no big deal. Shoot me your address, I'll dig it up tonight and ship it off tomorrow.
You've got me thinking about something counterintuitive: Are the steels which need large angles to take polished finishes able to hold thinner edges with coarser finishes? It's counterintuitive to me because polished edges seem more resistant to chipping and corrosion for me.
Downloaded the source for that cutleryscience blade materials page and searched all the links, but no luck yet. But I'm like a terrier, so not giving up yet....
I think what you're suggesting is possible. Based on discussions I've read about the "self-sharpening" effect seen with some blades, it kind of makes sense to me that high carbide steel run at low angles could be more likely to microchip away, rather than wearing down more smoothly, and so keep a good level of slicing aggression. This sounds like an interesting little study for the Brogan Blade Testing Institute to conduct.
BTW, when I took my JYD2 down to 3.5" blade length, I had a strip of 13C26 from cutting down the spine with a Dremel cut-off wheel, and did a bit of testing on it. Amazingly tough for a stainless at that hardenss, can be bent to where it'll take maybe a 10-15 deg. set before breaking. I've done similar tests with VG-10 and it just snaps without flexing at all, and though all subjective doesn't seem to require near as much force.
Been meaning to find out, I know the VG-10 Caly3 can't be disassembled, or the pivot adjusted. Same on the ZDP/cf version? Also wondering how sharp the jimping is; I really prefer a soft jimping like the JYD2, sharp jimping like on some of the Byrd line is a bit rough on bare skin for me.
Sounds like you have a bit of a preference for the Super Gold over ZDP, true? I was really hoping Kershaw would do a run of SG-2 Leeks like was being discussed, I've gotten a hankering for a Leek and that seems like a great size and package for SG-2.
Cliff Stamp said:I'd rather have a Calypso Jr. made of AUS-4 than an Extrema Ratio made out of ZDP-189
Doesn't it just make sense that a coarse edge is inherently less "stable" then a polished edge? Where does the optimum point lie between coarseness and stability?
I might email him for the info, just a little hesitant to ask a guy for his work kinda out of the blue. Dunno how that works, all the papers I've seen have either been through/for school work, or freely distributed online.
Hmm... going to have round up some files and anneal them in a pot of molten salt.
HoB,
One thing Gunmike1 and I both noticed is that edge angle plays a large factor in whether a specific grit feels toothy or polished. Convex an edge to 20 degrees per side or over with 2000 grit wet dry and it will feel fairly well polished. Leave an edge at 4-5 degrees per side with an 8000 grit stone and it will feel toothy.
As for rebevelling with the 120x D8XX, those scratches come right out with a 325 grit diamond or 500 grit waterstone (JoeC even has good luck removing them with a 700 grit Bester waterstone. Those 500 grit Glasstones are good, but some other stones are Bester).
I have some friends who are seriously into Jack Russell terriers ... and smart as they are they've still got way more cojones than they do brains, tenacious as hell.A pit bull or like that dog on Frazier?![]()
I've thought a number of times that the Sandvik steels are almost carbon steel-like in some ways, relatively speaking. Which isn't to knock VG-10 and others, just that the range of properties we see anymore in the stainlesses is pretty huge -- and a good thing, IMO, as more choices = more fun for us.That's very cool! When I rolled the edge on my External Toggle (same steel; same company; but a knife I like even better), the edge just rolled and looked all rolly (happened to a Swamp Rat Howling Rat, too, with the same rolly look), but when I've done the same on VG-10 and SG-2, it looked all cracked (which didn't happen when burring those steels during sharpening). Weird, different, and yet similar.
Having never handled a ZDP Caly3 I wasn't sure, but that makes it a very, very desirable package IMO. Carbon fiber is my favorite synthetic handle material, and I much prefer wire clips. Oh, this could get expensive.The pivot on the VG-10/G10 Caly3 can be tightened, loosened, or even completely removed and thrown away (don't do it, though - it really helps the knife work better). The jimping is sharper than the JYDII, but it don't bite fingers like you may think and the pocketclip is my favorite pocketclip ever (though, if you get the G10/VG10 version, be sure so sand the G10 where the pocketclip contacts the scale or else the G10 will sand your pocket). The CF/ZDP one is more comfortable to use and carry clipped.
Like I said, this could get expensive.Didn't realize it, but, yes, I like it a little better. Easier and quicker to sharpen (not by much, though) and the edge lasts just as long with light cutting. The Leek is one of those knives that does great in ZDP-189 and 440A. That Onion guy is no Tim Galyean, but he knocks a few out of the park now and then.![]()
Damn you, thombrogan! Anyone with an ARM that resets in the next few months would be bankrupt if they listened to you!When the JYD2 comes out with SG-2, it'll probably be more of the same.
It makes sense when you think of the angles, and how an edge at 1/2 the angle of another edge will have microteeth twice the size (first pointed out to me by Mr. Stamp).
Actually I'm more like an old, yellow lab, sunning on the back porch.
I guess part of my point was that edge stability should be referenced with some of the constraints that are used in determining it (you can say this for most measures of knife performance, too). And since I (we??) am not even aware of what the test is, it is probably premature to ask for what the constraints should be when using it!
A coarse edge will complicate the matter of stability greatly, I think. A coarse edge will make the knife more prone to wear (lose material) from the edge - kind of ties back to the edge that stays toothy and cutting well despite wear. I suspect a toothy edge may have wear factors that are many times greater than looking at the same wear factor in a polished edge.
I would think there is a way to calculate the deepest depth of the micro-teeth based on the edge angle and avg size of abrasive - the angle will make a big difference here, especially at small blade/edge thicknesses (which will also vary due to the abrasive size). If your abrasive size is 40 microns, can a good sharpener achieve a consistent 1 micron edge with abrasives that large? In theory probably, in practice I don't know. Burr removal will also be much more difficult - it'll be tough to get to the burr at the bottom of the microteeth. Here is an edge where an observational measurement of sharpness (edge width) might not be as good as REST or other test to measure push cutting sharpness.
Has anyone done slicing edge retention tests with serrated blades? If 80 grit is good, maybe REALLY coarse is even better? Now those are some big honkin' microteeth!
And would these gigantic "micro-teeth" would be less likely to deform or chip than smaller micro-teeth?
Yes! Cliff found that D2 with a *really* coarse finish will cut almost forever. I'm discovering the same thing also.
Well, maybe I should have phrased that better. It is not so much that I don't get the scratches of the XX DMT out with a different stone, it's the roughness of the edge itself. I just used it early today and yes, it will rebevel in a hurry, but the burr....! It feels to me like what Jeff Clark always said: why pull up a burr when you have to chase it later?
The angle dependence of the finish isn't much of an issue for me, since, as I've said, most of my knives are all around 12 deg, a couple at 10 but that's not that much of a difference.
I usually cut straight into a stone to remove the massive burr raised by a major rebevel with heavy pressure from the D8XX. Once the main bevel has been set and the burr removed by cutting straight into a finer stone, the D8C refines the edge pretty nicely. I know what you mean about that burr though, it is sometimes a MASSIVE ragged hunk of steel hanging off the edge. That can be avoided by honing the very edge with a finer stone after doing the major work with the D8XX, but I found that cutting the burr off and going to the D8C works pretty good for me. I must admit though, sometimes even after cutting into the stone there is some residual burr left, and again the D8C can remove it by honing at a higher angle, then going back to your normal angle to reset the edge angle you want. I will put up with that burring for the ability to change a 15 per side ZDP 189 edge into a 10 per side edge in only a couple minutes. I really like the D8XX, and all but one of my knives has been rebeveled on it (the one I didn't use it on was about 9 degrees included, I figured that was thin enough).
Pretty sure you had that knife going at 8 degrees.Aogami Super; as heat-treated by the d00ds at Takeda Hamono; is, well, super!
Would a 4000 finish at 10 degrees be as toothy as a 2000 at 20 degrees? I’m going to have to do some low angle grinding I have to see an 8000 finish that is toothy.
Well, even according to the theory the valleys are only 8 microns deep at 5 deg per side, which is pretty extreme. It is possible to see 8 microns with a 100x microscope, but it's getting pretty small especially since you are not looking at something flat but rather something that is slanted. Depth of field will be a major problem imaging that, but it might be possible.I have to see an 8000 finish that is toothy.
Thanks that is much clearer than what I asked and was just what I was wondering. I'd assume those of us that like an edge with a certain amount of bite indeed need a few different stones if we sharpen different knives to different angles to get the edge effect we like. I also am guessing this is why so many people seem to get different results with the same stone/hone from one another. Back when I was trying to find an all purpose edge I really like I never really thought of finish and angle affecting each other. I did play around a little with scratch pattern and how it could effect how a knife cut. If you angle the scratch pattern you can notice a different resistance on a forward , pushing slice, and a backwards, drawing slice cut. However, what I ended up with for an edge had alot more to do with ease of sharpening and how I sharpen freehand, more so than any smallish performance difference in the edges.if you would compare 2 micron grit at 10 deg per side against 4 micron grit at 20 deg then, no they don't give the same finish. Particle shape and pressure and direction of the stroke all equal, the finish on the 4 micron grit at 20 deg will actually be finer than the 10 deg at 2 microns. The particle size enters proportionally, while the angle enters as the tan, which is very non-linear.
From your many posts it seems you and I appreciate 13C26 for all the same reasons (I wonder if those who've been critical of Kershaw's current heat treat and use of this steel have tried it ... it certainly blew away my expectations.) When I did the rope cutting tests with the JYD2 I was amazed how the edge held up, not only was it essentially flawless when freshly sharpened, viewed under 40x magnification, but it seems the least prone to chipping of any steel I've used. In fact I like it so much, I've got an ENER-G on the way!The carbony effect you're seeing might well be the particle size and volume of the carbides that Larrin Thomas, Roman Landes, and Cliff Stamp have discussed. According to Larrin, AEB-L and 13C26 are similar to 52100 and Hitachi/YSS White Paper steel in terms of carbide size and volume as well as martensitic grain size and attainable hardness. Probably explains why me 13C26 Kershaws sharpen up so easily and don't do courtesy microchipping when the final edge (or microbevel) is below 30 degrees, too. Or in shorter sentences: Yeah, more fun for us like youse said!
