- Jun 3, 2019
And really cool tack and leather goods!!!Thats above my pay grade. I'm just a pretty good cowboy that makes knives.
Horsewright
Yep, you can put on the primer on one side and let it dry and it can even be up to 30 days later.
Apply the 324 to the other side and press together and hold for about 3 minutes and it is done.
Speed bonder 324 gives you a few minutes , 325 and 326 I think you only have 1 minute.
Thanks that good to know. We still need to get together at the ranch!
Thanks, in that pic above I made my leggings, spur straps, belt, holster, (knife and sheath above my left front pocket so ya can't seem em in this shot), reins, headstall and curbstrap. That also keeps me out of the bars.
I guess ihad envisioned pre drilling the bolsters before gluing, truing up the front and back with bolsters connected, but not on blade, and fnishing the front of the bolster before gluing (gets the alignment correct and avoids sanding the front of the bolster when on blade)Epoxy 1 bolster, with 24 hours drill holes through 1st bolster then epoxy 2nd bolster and wait another 24hrs before redrilling hols, pinning
I have tried this but had some disasters with broken bits (runout issue on drill press) so I found drilling 1 bolster at a time was safer. Then I found it safest to drill 1 on the blade, epoxy the second then drill through both.Im not advocating my method, it just works me and my setup and crappy drill press
I really don t see how that could work ? When we peen pins they expand , if you do that on mosaic pins something MUST give ...like epoxy will crack , the outer tube deformation ...etc . Or you smack them for no reason at all and when you grind them down to match bolster you get that perfect look ??I really just smack em with a hammer like everybody else does. Of course you deform the top but you are grinding the bolster down some anyhoo to blend handle and bolster and to get all hammer marks out and you still have the taper If you don't go really thin which I don't. Really does work
You're basically a wizard...
Horsewright- it sounds like you manually align the fronts of the two sides of the bolster before drilling into the second side? Do you see a downside to drilling the bolsters. Then connecting with temp pins and finishing the front and backs - thus giving automatic alignment?
Drill one bolster, then superglue together and use those holes as a guide to drill the second bolster.
I like to peck drill so the hole does not wander.
You can then adhere the bolsters, insert wax pins, clamp and let dry.
Then when dry you can tap out the wax pins, clean holes, and then shape the bolsters to completion.
Taper holes
Insert pins and peen and sand off pin heads for an invisible pin
For those concerned about performance over time, especially with your reputation on the line with customers, i would urge caution in jumping right to the speedbonder approach. It sounds good from a mfg point of view, but unless there is solid information on the strength/robustness of the bond over time, you might be heading for problemsHorsewright I would give that speedbonder a whirl. I've used it only on my last 5 knives and my Gflex and superglue has sat unused...
It's a little different thinking your way through the order of operations when you can put just the epoxy on with the pins.
Speedbonder went on the blade tang and pins. Activator spray went on the scales and pinholes( the pinholes are likely not necessary)
I also did a little tiny bit of activator on the pins tips after it was clamped. 5 minutes later I am grinding the handle!
