- May 4, 2012
First... we all know knives are tools and meant to be used.... knives are meant to show wear eventually, so there's point in debating that.
However, when I purchase several knives from a company totaling $780.95, there should not be any shoddy work or poor tolerances.
If the knives were used or previously owned it would be a different story... the knives in question that I received were "new".
Q.C. / Quality Control exists so a product does not leave the factory floor unless it passes inspection.
When someone spends $780.95 on several knives or any amount of money, it should not be a roll of the dice whether what is received is high quality in fit/finish/tolerances.
I purchased six "Lion Steel Shuffer's" (slip joint knives) from U.S. dealer "Collector Knives" totaling $780.95, unfortunately four out of six have issues, the other two are perfect.
Additionally, none of the "LionSteel" boxes the knives arrived to me in had names or product codes on them.
The dealer has not responded to an email and the manufacturer has not responded to three or four emails.
The issues:
Model: "Shuffler" clip point slip joints.
#1 Stag Horn. ** 1 rear screw not "set in" correctly, not 'flush' with scale as all others were has now fell out. Photos.
#2 Bocote Wood. ** Has an obvious piece of wood chipped out or cracked next to 1 front screw. Photos.
#3 Black Carbon Fiber. ** came with obvious scratches on the blade.
Photo.
#4 Natural Micarta. ** Scratch on blade. Photos.
#5 White Carbon Fiber. **"no problems/no issues/perfect".
#6 Rams Horn. ** "No problems/no issues /perfect".
I emailed detailed photos and descriptions of the issues to the dealer "Collector Knives" and NEVER heard back from them.
I have emailed "LionSteel" three or four times describing in full the issues including photos.
And stated I'm willing to pay for if necessary 1 or more replacement screws.
At this point, one of the screws that was never 'set into' the Stag scale/knife correctly has fallen out and I requested from LionSteel a replacement or few of them which I will gladly pay for if necessary.
All of the other knives have the screws set in correctly... 'flush' or slightly below the surface of the scale as they should be.... however the one (1) screw in question had an obvious problem when it was first received by me, the screw was raised up protruding up above the scale, very noticeable especially when felt with the thumb or any finger and could not be screwed down into the scale.
At this point I really want to resolve the problem with the screw that fell out.
Again, at this point, I'd like to request a replacement screw or a few of them which I will gladly pay for if necessary (photos enclosed of the original screw not "set into" scale correctly and then missing after it fell out(.
I have had ZERO response from both the dealer 'Collector Knifes' as well as the manufacturer 'LionSteel'.
The issues:
Photo.
