- Jan 6, 2007
Dennis, thats what Im understanding also.
So in fact you've just proven the carboard test to be useless in edge retention testing. Since it doesn't test the edge but the thickness of the blade?
Am i getting that right?
I don't think cardboard cutting is useless, but blade profile as well as the blade steel are variables that impact the performance when cutting cardboard. So the results can be misleading if the blade profiles are different and you don't take that into consideration.
If you compare blades with different profiles and different steels when cutting cardboard, then attribute the entire difference in performance purely to the steel, you may reach an incorrect conclusion.
But cardboard cutting is an excellent method for comparing the slicing performance of two different blades. (Cardboard cutting is the basis of CATRA testing.) You just need to remember that you are comparing the blade steel AND the blade profile, rather than just the alloy.
Hardheart, as usual, has given a much better and more complete answer than I have. Thanks for that.
I didn't mean that cardboard cutting is useless. Merely that it's useless for an edge retention test. Since after a certain point it seems that the only thing that is relevant is the thickness of the blade, not the type of steel or even how "sharp" the edge is.
Your own experiences seem to point that towards the idea that 2 knives being of different steels but the same grind/edge thickness come out to equal results on cardboard tests.
At least, that is what I understood from the discussion so far.
(not trying to argue, just trying to form some kind of conclusion from the results.)
