Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
In didn't mean to imply that it would not work.
The motor shown draws 5.56 amps and the VFD provides 6.7amps. That is enough, but not a large margin. If the motor is stalled slightly by heavy hogging, the current draw could spike as much as 15-20%. That would bring the draw to 6.4 to 6.7 amps........right at the max load for the VFD. As In said, probably not an issue, but I always go on the higher side.
I am sure that many of these have worked well for a long time. As Brian pointed out, if set up right, there will be no issue.
Another reason to have a bit of wiggle room is if he replaces the motor or builds another grinder with a 2HP motor, he would not need a larger VFD.
