- May 9, 2005
Ok I have been doing a lot of research on this knife lately and am now the proud owner of one, but I find that many people have nothing good to say about this knife! Why is that? I mean I have read everything from this thing is ground on the wron side, it sucks at cutting, etc. etc. The thing is those remarks are all crazy...why on earth would you get a knife designed strictly for close combat...a knife intended for a weapon, to skin your apples? This knife was never intended to be used to cut boxes and whatnot, it is intended to be a weapon. With that aside I want to address the common remarks of the grind being on the wrong side for right handers.
Ok think about what this knife was designed for...CQC (close quarters combat). Now with that in mind think about how people in this situation will, 90% of the time, have a nice small compact handgun and a knife. This knife was intended to be used alongside a handgun. Did it ever occur to anyone that it is ground the way it is because it would be held in a nonconventional manner? When actually in a CQC mode of sorts the user will have the handgun in the righthand, held as it is supposed to be, while the knife, or the Specwar in this case, would be held in the lefthand, upside down with the handle butted up against the grip of the gun, allowing both to be held simultaneously while keeping control of the gun. Does this makes sense? They use this stance, so to speak in CQC so one can quickly switch back and forth between knife and gun. When the knife is held in this manner, the grind makes perfect sense. Think about this, hell get a knife out or a SpecWar out if you have one and try it. Also, if you have ever seen people actually fight with knives they do not hold them upright in the conventional way because holding them upside down allows for a far greater range of movment. Does any of this make sense? Hell ome people in the military actually grind down the grips of the gun in the shape of their knife handles to better accomodate the knives when they are in this CQC sort of mode, course the grinding depends on the gun and the grip material LOL.
