OK, let's talk.
Titanium certainly has had the "buzz" for a few years. The "name" being used on everything from electric razors to watches and pens.
The advantages of Titan alloys are many; corrosion resistance, strength per weight, natural texture, good spring tension, the ability to gaul against steel (which aids in locks not slipping), electrical coloring of the material. There are probably some I'm missing.
The disadvantages, if you can call them that are more cost related; high cost of material, machining and finishing costs are higher. Titan does wear more than steel. I don't consider Titan a really good blade material, although in some situations, it works well.
We have no problem with making frame-locks from Chris Reeve. Chris and Ann have given us their blessings and we always give them credit for the lock when we usd it.
The ATR in Titan was well accepted in the marketplace, the reason for disco' was vendor probs.
As far as production, we do have a byrd model with a "Chris Reeve style integral Titan lock" in the works.
We have several integral "Compression lock" designs in Titan, primarily because the Compression lock is so much stronger than an integral "linerlock".
So my first question would be; is it the useage of the material as a "lock" that is desireable? And must that lock be a linerlock style, as opposed to a compression lock style?
Then, is it the use of Titan that is desired, other than as a lock?
The Lum Chinese folder has come up. What other existing designs (or new designs) do you think we would be successful with using Titan?
sal
