- Aug 31, 2009
Also saw no mention of blade thickness. Please tell me it's 2mm. At most 2.5mm.
If the demand is sufficient to add a clip, Eric and I will design one for the model.
sal
wharncliffe and m4 was all I needed to hear, I'll be in for one.
Ever consider putting a washer, or two short lengths of wire the same diameter as the wire in the clip, under the screw head?I'd really like to be able to remove the clip on my Chaparral and still keep a tight bolt on the handle.
Nice looking knife, but the wrong handed lock and non-stainless blade are both deal breakers for me.
If the female half is all the way in from the left, then nothing can pivot when you remove the male half of the screw assembly. If it's not all the way in, then the right scale can rotate. The liners are held in place by the blade pivot, lockbar pivot, and spring carrier/backpacer screws, so they can't moved even if the female screw came out far enough to all the way out. However, at that point the backspacer/spring carrier will pivot and be quite difficult to get back in place. But the female screw is under tension from the backspacer, so it won't just fall out on its own. Pictures of one with the scales off here.If you remove the screw that holds the clip on the Chaparral, will the handles pivot and will this cause a problem while adding a washer?
It would be easier to lose a knife at small with a clip, you wouldn't even feel it as it fell out of your pocket. It's inconsequential really. Get a small pocket sheather made fom calf skin, problem solved.yeah no clip is a bummer. I keep thinking about buying a kiwi, but the lack of a clip always helps me keep my wallet closed
Paul - Thanks. When you refer to the right and left scale, which one would be up if the side without the clip is flat on a tabletop?If the female half is all the way in from the left, then nothing can pivot when you remove the male half of the screw assembly. If it's not all the way in, then the right scale can rotate. The liners are held in place by the blade pivot, lockbar pivot, and spring carrier/backpacer screws, so they can't moved even if the female screw came out far enough to all the way out. However, at that point the backspacer/spring carrier will pivot and be quite difficult to get back in place. But the female screw is under tension from the backspacer, so it won't just fall out on its own. Pictures of one with the scales off here.
Chiming in...
I would be fine with no clips in any Spyderco knives. I almost never use them.
not exactly.
some people prefer a clip and not a calf skin pouch. rightfully so imo...
People who ant a gentleman's spyderco without a bunch of holes drilled in both ends aren't so lucky, though.
