- Oct 5, 2006
Spyderco Civilian & Matriarch Review
Introduction
After years of owning Spyderco knives, I finally acquired a Civilian and a Matriarch this year. As many folks know, the Civilian is a legendary self-defense knife designed in the 1990s for law enforcement use. The Matriarch is is a slightly smaller, lighter weight version of the Civilian with a thicker tip.
Size & Weight
Before owning them, I found it hard to get a sense of the size comparison, so I'm posting these photos and a table to help others. As you can see, the Matriarch is about 50% lighter than the Civilian and gives up 1/2" in cutting edge.
Handles
The black G10 Civilian handle is similar to that of the Spyderco Military, but thinner where the liner lock would be on the Military. In contrast to the Military, however, which has liners on both sides of the G10, the Civilian has a liner on only one side. The Matriarch has the same FRN volcano grip handles as the older Spyderco Enduras or the Pacific Salt series. Both are secure lockback designs featuring the Boye dent. Both are also tip-up carry only, although you can reverse the clip on the Matriarch for left-handed carry. Both the Civilian and Matriarch are assembled with screws, rather than pins.
Blade
The Civilian's reverse "S" blade is hollow ground and comes in serrated SpyderEdge only. The Matriarch's blade is flat ground and available in plain edge or SpyderEdge. Both are 1/8" thick at the spine and are ground from VG-10 stainless steel. Unlike many Spydies, there is no jimping on either blade.
Conclusions
Normally, I'd use this section of a review to describe the knives in use. The Civilian and Matriarch, however, aren't designed for everyday use -- on the contrary, they are knives you hope you never have to use. Both of mine were shipped with tags tied to the handle that say: "NOTICE! This knife is NOT designed to be used as a utility knife. Its unique design will not support everyday use and our warranty will not cover the results of using it as a utility knife."
They both carry well in the pocket and are available from time to time in limited quantities. They are made in Seki City, Japan. The MSRP on the Civilian is $269 and you can find them for sale for $175 or so at our favorite online retailers. The coco brown Matirarch was offered recently as a sprint run at an MSRP of $99. As far as I can tell, they are sold out.
Introduction
Size & Weight
Handles
Blade
Conclusions
