Spyderco Civilian Questions
Let's bring this discussion back to the merits of the knife as EDC!
That thin tip makes it the best letter opener I've ever had. :)
Works great on blister packs.
Sharpening pencils with it is a breeze.
For light EDC use, it's fine...just don't do things that'll break the tip.
Utility use voids the warranty, so don't make it so you need the warranty. ;)
Perfect! Exactly that for which I was looking; thank you, stabman. :)
To quote Mr. Keating:
"So, the tip is an extractor. Meaning; rather than trying to find the weaknesses about this tip and saying: 'Oh jeez it's, it's too delicate' and things. Use that delicateness! Insert it into a wrist and pop out a tendon...'"
More to the point:
"You don't want to lose your knife. You don't want a dull knife. Get a Spyderco serrated sharpener for something like this and keep this sonuva***** sharp. If you have a dull knife, especially this, IT WILL FAIL. You will hook up and NOT CUT. You will get caught in somebody's army jacket or something, do no harm and merely and lose your weapon. So the knife must be kept sharp...sharper than sharp because this has to cut through clothing."
If it is an EDC, it is EDC Combat.
Sorry if it sounds like I should be posting this in another forum. I think I'll pipe down and let someone else share their input. Hope no one is offended.
More to the point:
No offense taken by any means; I do certainly appreciate your input. I'm just steering the discussion a bit, because there is plenty of information and are plenty of threads about the Civilian for SD, but few that really poll many people whom have at least tried it as an EDC. I understand, and agree with, the original intent with the design that's been chosen, but the curious knife collector/user in me is interested in the idea of its potential alternative usefulness.
I have a civilian have used it very little and tip is still intact. I know it won't stand up to any sort of prying. But I don't carry it and it rarely even sees light. Too impractical for anything except scaring people. In a life or death defense situation I almost always have a better alternative within reach.
Good evening everyone,
I know these posts come up every so often regarding the infamous Spyderco Civilian -- just how delicate is the tip? I've done every bit of internet sleuthing I could and have read every thread and review about the knife that I could find from within the last 15 years. The final conclusion of them all is that of the reason the knife was created - self defense and not utility. While I fully understand the intended use and design, I am still drawn to this knife, however impractical. Because I could pull it off, I would end up carrying it as a light-duty EDC if I were to purchase it. I have found that the early models were truly poor for even this use, as the tip was manufactured to be even thinner, though the modern ones have a bit more stout tip. For these uses, such as opening letters, packages, occasional impromptu steak knife, normal cardboard/zipties, etc. should I expect the tip to receive significant damage?
I would prefer to steer the discussion away from the fact of why the knife was created, as I have read the story of it dozens of times in the aforementioned threads. Rather, I am looking for some input from those who have carried it as an occasional EDC for regular use as to if your Civilian has sustained any significant damage in doing so.
I would also greatly appreciate some comparisons. My first true EDC was a base model Kershaw Leek. This knife is also well known by many to have quite a delicate tip. I've had multiple Leeks, a CRKT Eros, and a Protech Godfather, all without every damaging the tips of the knives. As such, could anyone compare the tip thicknesses of these knives to that of the Spyderco Civilian?
Thank you for any input, information, or stories anyone may be able to share! I look forward to your responses.
The Civilian is the only folder I ever carry: I got my first one 16 years ago, and never carried another folder since (I prefer fixed blades for actual use)... At the price, and given it cannot be sharpened by me, I would never think of using it, but it could do some everyday tasks if you are rich and can buy a new one every year...
I had an old aluminium one, and now have a new G-10, with the infinitely better pivot: There is no real difference in how the tips were made over time, because each individual knife varies enormously: Some are very strong, some are one quater to one third thinner: The base of the v of the tip varies from 0.85 mm to 1.17 mm on two G-10s I compared, and I had two of the same vintage when I made the observation... For a Seki city made blade, that is truly an enormous variation: Around 30%!!!... At 1.17 mm the curved tip is very strong because of its curvature...
When I lost the Aluminium version I was carrying for 15 years, I ordered 2 to pick the one with the best point thickness and lock up (I had sent back an aluminium one 15 years before because the point was way too thin: Perhaps as low as 0.7 mm): To my great fortune, both the best lock up I ever saw and the best point was on the same one: I promptly sold the other...
It was fascinating to compare two brand-new G-10s: You can tell this is an extremely difficult design to execute, because despite the Seki origin, and being both new and of the same vintage, the two blades were completely different in blade width and geometry: One had a much broader blade near the inner curve peak, with a thinner grind with a shallower bevel (thinner tip too), the other, the one I kept, had a much narrower blade, with a more open blade grind but a much higher edge bevel, because the blade was narrower and thus thicker and more open-angled near the bevel: Interestingly, because of the higher edge bevel, there was no difference in sharpness between them, though the one I sold would probably take to resharpening better, if that was even a consideration for me. I can't see how resharpening should be a factor here, since it would require some really specialized tooling...
The 15 year old Aluminium one was probably closer to either of them than they were to each other!
Don't ever try to reshape the tip stronger: It has a hollow shape that is essential to the design, and one that you coud never replicate even with a rod sharpener... Not to mention all the polish would go out to hell, which means the cutting performance as well, since that is the one knife that depends on polish to cut well, not geometry...
In my opinion it is the strangest and most unique knife design ever invented: Not for utility, but for defense and combat. I would place it as one of the greatest knife designs in a century, if not more... It real advantage for fighting is something few people have showed any real understanding of (at least I've never seen it mentionned anywhere): Because stabbing requires an extension of the arm, the reach of a stabbing knife is actually well below an extended arm: More like elbow reach at best... Not to mention needing the other hand to hold the target in that pathetically short range, which is why so many stabbers end up stabbing their own other hand (Police always ask to examine hands in a car full of stabbing suspects, and most of the time, guess what)... The Civilian is designed to be used effectively at the end of a fully extended arm, without any holding back the target with the other hand, so it actually outreaches almost all other knives, with their flesh pushing tip geometry (and amost all conventional knives grow much duller towards the tip: It's just in the nature of conventional knife geometry): Pushing flesh means the "point cut" will be much shallower, and will most likely be further compromised even by light clothing, since the flesh moves back, as well as the stabbee...
So the Civilian is a folder that is litterally bigger than its size would indicate...
G.
G.
That's a great experience. I had read somewhere that the majority of the blade finishing is done by hand, specifically the tip, so it may vary; it's interesting to know that it can be that significantly. I had never thought of such, but it may be beneficial to contact Spyderco about shortening/thickening the tip a hair, before I may break it off. I'll keep that idea in mind for when I pick one up. Thanks!
I have one and I carry it, but I don't use it for EDC-ing as I have another knife on me that I do use. The civilian is there just incase anything goes bad!
Over the years on the forums, most people want their civilian or matriarch factory sharp and thus don't use it for anything other than self defense. Except for a one time demonstration with some towels and jeans, the blade is factory sharp, but the clip shows routine carry.
Years ago Sal said there at that time were two non-self defense uses for the civilian he knew of, film cutting and mushroom gathering :)
I'll tell you how delicate it is in my experiance....
A few (3 or 4?)years ago I bought one from a knife dealer, who said he was an
official dealer, at a local gunshow.
I thought it was amazing and beautiful...
I planned to carry it(occasionally) for it's intended purpose and mostly
just to fondle and show to friends. A few days after I got it I was
playing with it. You know, just opening, closing and admiring as we all do
sometimes with a new knife.
I let it close, with just the power of the back spring.
Due to a lack of stop pin, the tip hit against the backspring and
about a 1/2 inch of the tip snapped off.
I sent it back to Spyderco TWICE and they refused to help both times,
even after repeated phone calls and letters.
I was NOT flicking it closed. I was NOT squeezing it or in any
other way abusing it. Just let it close like normal.
And they would not help me.
Because they would not help me is the reason I refuse to buy
another Spyderco unless it's on the secondary market and cheap.
No matter how sweet they may be. (up to that point Spyderco
was my favorite knife company)
Anyway, I reshaped the tip as best as I could but it was never
the same and just made me sad. Eventually I was mad at it and
decided to grind off some of the back to "wave" it useing the
Spydie hole. (Not until a year or so after they wouldn't help me)
That worked well but... Now it just sits in a box somewhere...
It'll probably never make me happy again.
Anyway, that's my rant/sob story.
If you get one, hope it works out alot better
than my experiance.
This makes no sense.
Due to the design of the knife, the blade does NOT contact the backspring, no matter how it is closed.
I find your story...odd, to say the least.
Intimidating someone with a knife is a tactic that can be read through and WILL get you killed. Knives are meant to be felt, not seen. If anyone carries the Civilian or anything like it, they had better make the decision to use it and do whatever is needed to save your life. Scaring people with knives is for high school punks in gangs.
I am talking hypothetically. I am not a punk in a gang. I don't go around flashing a knife around and scaring people. I was making a point. Do you own either one? I have both and was making the point that it was not designed to be an EDC knife.
Knives are meant to be felt, not seen? Are you kidding me? How many people have you stuck, Killer?
If you're going to come on here, pull things out of context and start lecturing people you don't even know save us the trouble and go away.
Find it odd if you will, but that's what happened. Many lockback designed knives are made without
stop-pins and if squeezed the blade will contact the backspring/or handle frame. In my case the tip of the
Civilian(older version) was very close to the backspring even normally. Like, 1mm distance at most.
The momentum of the blade closeing freely allowed it to basically squeeze itself... "overclosed?"
Believe it or not doesn't matter. It happened.
stop-pins and if squeezed the blade will contact the backspring. In my case the tip of the
Squeezing my Civilian right now...Blade does not move at all.
On the traditional Buck folder, sure, squeezing it makes a difference.
NONE of my Spyderco's do that, because they are designed not to.
Perhaps the older, way older Civilian wasn't designed the same as every other Spyderco I have held or owned; I guess such a thing is possible.
But the newer (2007 and up at least) models sure are following the general Spyderco design.
It isn't a thing of having a stop pin either, as Spyderco lockbacks do not.
Here's a thread that explains it: http://www.bladeforums.com/forums/showthread.php/1004337-Lockback-Question
EDIT: From that thread it does seem like some Spyderco's in the past have been done wrong in that regard...sucks that the one you got was one of those.
It can be sharpened the same as every other serrated knife.
The very tip bevel is a compound hollow bevel -hollow both vertically and horizontally- for extra sharpness. You can see they used a different tool than with the half moon serrations: The compound hollow can mostly be seen by playing the light accross it. The back face of the point is so narrow it largely precludes a good sharpening from the non-bevel side... This is realy a factory job only...
Even for the rest of the serrations (thus accepting the tip is not recoverable to even 50% of former sharpness), correctly sharpening the half-moon hollows would mean using very narrow rods on the bevel side, because the low sabre hollow grind makes sharpening the non-bevel side inefficient... That is assuming the professional sharpener even has the proper set-up of narrow wheels or rods to sharpen from the bevel side: Most will just sharpen the non-bevel side, but they can't even use their usual broad flat surface wheel because of the inside-curved blade...
Since the blade itself is almost entirely an inside curve, this limits the average user to sharpening with a rod sharpener: I cannot see an average user getting sharpness back much beyond 50% of brand new... Because of the low sabre hollow grind, it is in the same league as the Police model in being hard to restore, even if it wasn't inside curved... Maybe professionals can do a little better than 50%, but this is certainly not like an outward curving serrated edge on a full flat ground blade, which an average user can in some cases sharpen with just a flat stone on the non-bevel side... We are a long, long way from that kind of simplicity here... As far as I know, there is no factory sharpening service offered for the Civilian, so if you want to use this knife regularly, the easiest way to reharpen it to full performance is by far to just buy another one...
Even if a professional could sharpen it correctly, a very big if, the blade is so narrow he could only do it once or twice before the angle becomes to open, so I really question the value of sharpening it at all...
Gaston
Well, I don't know about what other models you may have.
Doesn't really effect the situation in question. The Civilian
I had, original version with a very needle-like tip, broke in this manner.
Like I posted in the edit, it looks like some models have in the past done that.
Seems like now they've worked out that kink. :)
Well, perhaps I miss-spoke then, let me try again: Die to a lack of
over-travel prevention, it closed too far. Better?
I still don't see how this effects my personal experiance.
It sounds like you are going out of your way to imply that
I'm lying and I don't appreciate that.
Naturally You post this while I'm typing my last post.lol
This post does have a different tone to it, so I appoligize.
I'll delete it if you like.
