But yes, it really does suck. I was fairly new, not to knives, but to high end
or better quality knives. The $150 I spent on it was very substantial to me
at the time.
It looks like the newer ones have a slightly different blade shape and I'm glad
they got that fixed. It does look very pretty.
I'll leave it as is to preserve the converstation for other readers
but thank you for doing the research and trying to understand my
perspective. Sometimes things sound odd, but are still true, as you
already know. It's hard to sort them though...
$150 isn't cheap (even after spending far more along the way, it still isn't cheap), and with the downward curve to the blade, having it able to move towards the backspacer like that is not good.
It really is hard to understand another's experiences at times---especially when they don't match our own---but it's worth it.![]()
Squeezing my Civilian right now...Blade does not move at all.
On the traditional Buck folder, sure, squeezing it makes a difference.
NONE of my Spyderco's do that, because they are designed not to.
Perhaps the older, way older Civilian wasn't designed the same as every other Spyderco I have held or owned; I guess such a thing is possible.
But the newer (2007 and up at least) models sure are following the general Spyderco design.
It isn't a thing of having a stop pin either, as Spyderco lockbacks do not.
Here's a thread that explains it: http://www.bladeforums.com/forums/showthread.php/1004337-Lockback-Question
EDIT: From that thread it does seem like some Spyderco's in the past have been done wrong in that regard...sucks that the one you got was one of those.
BTW, thanks for designing what I think is the greatest self-defense folder ever made. I really feel the need to say it.
Gaston
To the OP, as per durability of the tip, sounds like they may have
improved on that, and with he newer model, your experiance may be
much better than mine. But it does sound like edc may be a real
issue simply due to sharpening/maintenance.
Whatever you do, I hope it goes well. And sorry for semi-hijacking
your thread.
Hi Shrub,
Sorry for your negative experience. I designed all of our lockbacks to have the kick hit the lock at the lock pivot to prevent the tip from hitting the backspacer. That is oneof the advantages of the mid lock-back as I was taught by Al Mar and Harvey McBurnette. The Civilian is one of my designs and the tip should not be able to hit the backspacer. I was not involved in your cusomer service experience, so I never saw the knife. But I'm sorry you have a negative experience.
I agree with brownshoe on not showing and keeping it sharp. If you want a cutting defensive tool to perform at its best, and it's a Spyderco, better to use another EDC and leave the edge pristine. You hope never to use it (like a spare tire) but, IMO, give yourself the advantages of a very sharp edge.
sal
I did not design the knife to be used as an EDC. I wouldn't use my Civvie or P'Kal as an EDC. I would carry a 2nd knife.
sal
