DeadboxHero
- Mar 22, 2014
Jpm2, did you Rockwell test yours?
My experience is very positive, as it is with all hss blades I've used.
My only gripe with spydercos version is low optimal hardness.
Nah, but we've already been through this here.Jpm2, did you Rockwell test yours?
"The maker says the hardness is Rc 63-64.
sal"
I have an M2 knife that the maker lists at 59-61, it's the softest of the ones I listed earlier, and it's slightly harder than my haps.
If by testing you mean, using, sharpening, scratching against other knives ... yeah, they were tested before our 1st conversation.Yea, just checking again. Maybe you had them tested since last time.
(Shrugs)
Ok, I worded this wrong, don't want readers to get the wrong impression.My experience is very positive, as it is with all hss blades I've used.
I've finally bitten the bullet and purchased a BNIB Hap40 Delica which I should have by the end of the week .
I'm interested in trying to get some patina on the the Hap40 edge . Any suggestions as to what really gets the process happening ?
Mustard , Lemons , Vinegar ?
A lot of the reason I've held off buying one , other than the silly price that they cost down here in Australia is the handle scale colour doesn't really appeal to me from all the photos I've seen . I have blade swapped a few of my other Delicas so if it doesn't take my fancy when it arrives the blade will probably go into some different scales .
ZDP189 is my favourite Seki steel so far so it will be interesting to see how the two compare .
I've been on a Delica buying spree lately and my Kahr that I bought a couple of weeks ago is my new favourite , but man I wish it came in ZDP189
Ken
Ken
Again, I think Spydercos hap40 is excellent as is, just curious how it would perform if harder.
You can test relative hardness by attempting to mark/scratch/gouge the blade, below the laminate line, if applicable.
I know this method is frowned on, but curiosity gets the best of me.
edit - Also, the sus410 laminate might be a limiting factor in how the blade is heat treated, and to what hardness? Think this might have been mentioned before?
I think I'm going to trade my Endura in HAP40! Why? I want a Stretch or Delica in HAP40😉. The ergos of the Endura don't suit me, but I love the steel. Btw, my Endura was the very knife that Jim used in his rope cut tests. Maybe I can get it tested at work, to put a hardness with a single knife from a controlled test. Sal did mention that the maker is reporting consistent results on the heat treatment, but I don't remember the number.
If the C scale was not appropriate, they would go to the B scale. The machine is versatile and there are different tips. Sorry I don't remember the technical terms. My guess is it would still be on the C scale around 45-50.I thought a rockwell tester used the indetion depth of a specific size and shaped bit, with a given force, to calculate hardness.
How would this work with a softer outer laminate?
Yes...and I also thought the area tested had to be flat and even for an accurate measurement?I'm not sure, but he might have been asking how you would test the hap40 since the tang has the softer laminate. I guess you'd have to test the exposed hap40 below the lamination line but it seems that would be a bit more dangerous as the steel is pretty thin there?
My bad, I thought you just wanted to know the difference in final hardness between the two steels. It would be tricky, but they are doing it somehow.Yes...and I also thought the area tested had to be flat and even for an accurate measurement?
