fwiw - http://belgiansharpening.wordpress.com/2014/08/21/spyderco-manix-2-s110v-review/
There are conflicting s110v reviews out there. I need to make a few more s110v knives before deciding whether s110v steel is a good fit for my products or not. The 2 s110v knives I made were chippy until I lowered the hardness to 59rc and wear resistant was similar to s30v. Tests were informal, so scrutiny not![]()
I want to add that 62-64HRC is a working hardness of this steel, lower hardness does not make sense, does not differ much from s30v
I agree,there are many factors.good high alloy steel well keep the small-angle sharpening and lateral loads, for example 3V at 60-62HRC.It depends on intended usage. My requirement - take a 1x1" piece a dry oak or hardwood, vertically strike down onto the edge. Difficult for many high alloy steels to pass this requirement. So far only my D2 at 62+RC made it. Sure, can be said, don't use wrong steels for this tasks
I understand high alloy wear resistant reason for use these high carbide volume steels but inadvertent-chips are unsatisfactory for customers. High aust temp + cryo = easy high hrc. More importantly blade design & edge geometry + sharpening + cutting style are even more critical for intended uses.
So one person cuts up a cardboard box, and S110V chips badly.
Then another person cuts up a cardboard box, and the S110V rolls.
So one person tests S110V at a modest 15 dps, and the edge can't take it.
Then another person tests S110V with a super thin edge (0.005 at the edge shoulders), and it sets the record for long cutting through a harsh medium.
And yet another person tests S110V on the same medium, and it ranks as an utter fail.
Either people are not testing these steels correctly, or quality control by one of America's top knife manufacturers is a four-star horror show. I can't tell what is going on.
Steels this level is not for the average consumer,and have to be the potentials inherent in them.It depends on intended usage. My requirement - take a 1x1" piece a dry oak or hardwood, vertically strike down onto the edge. Difficult for many high alloy steels to pass this requirement. So far only my D2 at 62+RC made it. Sure, can be said, don't use wrong steels for this tasks
I'm not interested, empty discussion.I have no purpose to discredit.
regard sharpening 600 grit ,this is the case for some steels.depends on the structure of the steel and its hardness.I myself sometimes use this methodI did not need to imply that you had other intentions, I simply meant that the initial videos were not clear to non-Russian speakers. Thank you for organizing the videos and establishing some context, I look forward to watching them later this evening.
One other possibility: edge retention does rely on sharpening technique to some extent. For example, if a burr is left and is simply straightened out with stropping, then it will soon collapse during actual use and the edge will disappear rather quickly. So I wonder if since S110V is rather difficult to sharpen without the proper equipment, shortcuts and poor technique were used either out of frustration or to compensate for it. Now, the Belgian Sharpening link from bluntcut (as well as their own experience) is interesting because they obviously know how to sharpen, so perhaps that's not the case.
But in Ankerson's testing, I believe he used 400 grit. Some of these other tests used a more polished edge. I was actually curious about this a while ago and tried something similar out, but unfortunately, I didn't structure any proper testing. So while this is a subjective impression,when I applied a 1200 grit edge to D2, I saw that initial "razor" edge disappear pretty quickly, and it didn't "settle into" a "working" edge that well. On the other hand, when I stopped at 600 grit, that "working" edge it settled into lasted a little longer (again, this is subjective, but if I had to guess, it cleanly sliced paper about 20% longer than the 1200 grit edge). I might have to purchase another D2 blade to test this out, since I've since sold that particular knife.
So I wonder if the varying forms of edge deformation depending on the initial level of polish affect edge retention in high carbide/high wear resistant steels? Hopefully someone with a bit more experience could tell me if I'm barking up the wrong tree here, otherwise I may order a BK24 to test this particular hypothesis out.
As for s110v on 400 grit, I doubt very much that the knife will cut paper...
I'd be curious to see how it does after you have sharpened it like this. Initial sharpness can have a huge effect on edge retention, but I'm pretty sure you already knew that.I just resharpened my S110V Mule. At 400 grit, it didn't take a very good edge. It would not slice paper effectively, as Slava said. But by the time I finished -- 1600 grit ceramic followed by 1.0u and 0.5u diamond paste stropping -- it was razor sharp. Way sharper than the factory edge. On most steels, I can get a sharp edge at 600 grit or so, although I usually take it higher. But S110V didn't like the lower grits, but it loves the higher grits.
