Thanks brother!Awesome work, Josh. It's always a treat to see what's next from you.
I got cut just looking at this picture. That's a wicked looking grind Josh! Congrats Chad!Finished the first shaman reblade, headed to @cpirtle
Thank you!!I'm confused lol. Are you also customizing the handles too? Whatever you're doing, your attention to detail is amazing.
Not wanting to pull apart a perfectly good Para, it seems the liners are the only parts no so easy to obtain. Maybe a super loaded question but are the liners on Ali worth the effort? I say effort because of the possible/probable dubious quality.
Edit to add, scrolling through again it looks like the original blade is needed to line up the reblade?
Thank you for saving me the trouble, Josh.No that would be very sketchy to order from Ali for the liners... In fact I wouldn't even work with them as it would likely cause a ton of headaches on my end. But a few other very important components that need to stay OEM are the pivot bushing and the stop pin. Other than that everything can be swapped.
In retrospect makes total sense. Besides the thought of cheap guts holding everything together. I've always wondered just how much hand fitting is still required in these modern days of CAD and the like. I know you can get quality from that region but probably not so much from Ali.No that would be very sketchy to order from Ali for the liners... In fact I wouldn't even work with them as it would likely cause a ton of headaches on my end. But a few other very important components that need to stay OEM are the pivot bushing and the stop pin. Other than that everything can be swapped.
I would tooDamn!
You are spitting straight fire now. My problem is that I would ruin something that pretty.
