- Jan 17, 2016
The Spydie pamphlet that comes with the sharpmaker says it works for tool steel. Though I have no exerience with M4 and the sharpmaker.
I heard that the sharpmaker and other ceramic rod system isn't recommended to sharpen hard steels like M4 as it will cause chips, is this true? I am kind of holding back after i heard about this issue, Thanks!
-Kevin
Not even remotely true. Have no fear. I sharpen m4 almost daily on the Sharpmaker. The ceramic rods of the SM will work on any steel though I do admit to preferring diamond rods on some of the high wear resistance steels like s90v/s110v. Ceramic works just fine on those too but diamonds are a bit quicker and more efficient and I prefer a more coarse edge on those type steels anyway.
Attempt #2 this time with a s30v pm2. Much better.
Hi Nick, and welcome to the forum. A microbevel is not beyond you. It is by far the simplest way to sharpen and maintain a knife edge. Here's a few tips you can follow. There are a million ways to skin a cat but I'm going to outline what I believe is one of the simplest ways to learn.
Get yourself a set of the diamond of cbn rods for the sharpmaker and put them in the 30 degree side. Sharpen one side until you can feel a burr form along the opposite side. (Depending on how dull your knife is and how obtuse your edge bevel is this can take quite a while). After you have a burr, switch sides and sharpen the other side at 30 degrees until a burr forms on the first side. At that point alternate sides using continually lighter strokes until the burr is gone from both sides. Now your knife is sharp and you have a clean apex. All the hard work is done at this point.
From there, all a microbevel is is sharpening very lightly at a more obtuse angle (lets say 40 degrees since that's the other sm setting). You will find that once you do the first part right and have a clean apex, you can put an extremely sharp microbevel on with just a few passes and very light pressure. When your knife gets dull, just continue to sharpen the microbevel. This is way more fast and efficient since you are only removing a tiny bit of steel at the apex. Slowly over time and repeated sharpenings, your microbevel will start to take over your main bevel and you will need to go back and reset the main bevels to 30 degrees but it takes a good bit of use and many sharpenings before that is necessary. Take a bit of time to practice this and you will be very pleased. Don't tell yourself it is too hard. It's not. It is the easiest way to maintain an edge IMHO. You will definitely need the more aggressive diamond rods to do this with the sharpmaker though.
Im the guy asking the questions others are embarrassed to ask, but what exactly is a burr?
A big Thank you to everyone for helping me solve my curiosity! I guess i'll be picking up a sharpmaker soon! Ya'all Rock!
A burr means that the steel is thin enough at the top that it is folding over slightly, because the bevel you've just ground has reached the edge tip.- source knife center
You can check out the link below, i personally think it is very informative.
http://www.bladeforums.com/forums/s...Secrets-of-Sharpening?p=15571147#post15571147
-Kevin
This is what I thought it was. Thanks for the info.
