No, no, the kitchen knives are very hard, I was comparing the soft clad metal as being of similar hardness to folders with VG-10.
I dont get this thread at all, how can anyone seriously believe that AUS8 is as good as VG10? I like my Recon 1 but there is no way it holds an edge as long as my Endura 4. I always heard that AUS6 is about the same as 440A, AUS8=440B and AUS10=440C, VG10 is a lot better than 440B. It seems to me there must be a reason why AUS8 is found almost exclusively in cheap, low end knives and VG10 is found in more expensive, higher end knives. I would have been happy to pay 20 or 30 bucks more for my Recon 1 if the blade was VG10 or 154CM. You can get a Utilitac 2 in AUS8 for around 30 bucks, no way you could get it that cheap if the blade was VG10. From what I have heard and read AUS8 8 is about equal to that 8Cr13MoV stuff coming out of china. As for Ankersons rope cutting test, knarfeng did a rope cutting test back in 2008 with very different results, unless AUS8 is much better steel now than it was then, I would assume the results are still valid.
Check post #18 in this thread: http://www.bladeforums.com/forums/showthread.php/608209-VG-10-or-AUS-8
Apologies if I stepped on any toes, just telling it like I see it.
Do you have any other experience with those 2 steels in any other knife except the two you have? The people who are saying that there's little difference have A LOT of experience with those steels. More than just a one knife with each steel. What you may be experiencing is difference in edge geometry, edge finish, and heat treat.
Hello Ankerson
I have seen the difference in alloy content and I noted that VG10 has more carbon and a lot more molybdenum. Doesn't more carbon mean better edge retention?
One more thing, I have been watching your videos for a couple years now and I like them very much.
. I’d put more faith in Spyderco’s heat threat than Cold Steel’s.
So the high % of cobalt in VG-10 is not what's making the difference?
I’ve seen tests where Aus 8 and VG10 are similar in performance, but usually VG10 comes out on top. In my own experience, VG10 is a step up from Aus 8. But it’s difficult to make blanket statements because steel performance is so complex. Personally, I think the heat treat/hardening process is underappreciated, mostly because we have no idea what that process is with the knives we buy. We’re lucky to know the hardness – and then only an estimate of hardness. Take two knives with a stated Rc of 58-60. One might be 57.6, and the other might be 60.4.
But if they stay in this class that includes 440 A, B, C, 420HC, N690, VG-10, AUS-6, AUS-8, AUS-10 and the alphabet steels the differences will be small.
You put bohler N690co in the lower class? Man the Begg bodega is even more overpriced than I thought, lol.
It's used in a pretty broad range of knives from kitchen knives to, folders to larger field knives to diving knives.
Very popular steel outside of the US and has been for a long time.
Yeah im familiar with the steel. Many Italian makers favor the stuff. Im just saying that if the steel truly is lumped in the performance category of those other steels that I find it to not a a suitable steel for a $900+ knife. At that price it better be super steel.
