I am not comfortable with lower limitations either.
That is why I have found "the best" way to kill spiders around the house is with a 12 gauge.
Guaranteed kill!
You read into my post what you wanted to hear. I didn't say they weren't weaker than full tang knives. I said they weren't weak. There is a fundamental difference there.
And that difference would be ?
I have hunting/fieldcraft knives from every decade beginning in the 1890's until now, and all of them are still quite serviceable. My circa 1915 Marbles Woodcraft and my Remingtons and Western States still have another hundred years left in them if they wind up in the hands of people who know how to use knives properly and properly maintain them. Codger
I, personally, can't see any way to disagree with that. A dull knife won't cut well no matter how well it prys, and if you need cutting, it's not the "best" tool.Some very interesting points have been brought to bear here and at the risk of alienating myself even more from certain factions on this board, a bombproof unbreakable knife does not make it the best knife. If you use a knife mainly for cutting and slicing and very occasionally subject it to light pounding and prying almost any design will suffice. If your main intent is to beat the hell out of it all the time then you might need to get a specialized tool for your particular application.
Stick tang knives are not weak. ...the full tang can "theoretically" out do/last a stick tang. That does NOT make a stick tang weak. See, pretty simple.
Anyone that has any skill with a blade, can use a stick tang effectively, and safely so not to break it..
Geez.......... less material is less strong, IE; WEAKER, than more material. See? pretty simple.........
Then the Busse line suits your expectations. You were either taught, or learned on your own to have different uses and expectations for and of a knife than I. I simply choose different tools for the tasks you expect a knife to accomplish. Or I find a way to accomplish the task without endangering or ruining my knife. To each his own.
Codger
I have a Fallkniven Idun that is laminated VG10 with a stacked ox hide handle. I use it for a field knife during the bow season. Light skinning and quartering duties. Over the past few seasons the handle has taken on a nice color and it is very comfortable and non-slip. All the Northern Lights come with ox hide handles and in a variety of blade designs. Check them out.
a large tang incorectly or poorly (heat treated) may very well give way long before a smaller tang correctly heat treated will.
No kidding????????????..............
Codger,
Found another one and it says that it is STAINLESS.
I thought you said yours was 1095 ?
Are there two versions, or was the seller mistaken?
Assuming that were true, how thick should the full width tang be? I have a khukuri with a 9/16" thick full-width tang. Would a khukjri with a 1" thick full-width tang be "better"?Geez.......... less material is less strong, IE; WEAKER, than more material. See? pretty simple........
The knives I take off-road are expected to do the same, and have been doing so for some decades. They have more often been less than full-width-tanged knives because the full-width tang knife was quite rare until relatively recently.Some people think it is utter abuse to baton or pry with a knife. Whilst I expect my knife to handle that, should the need arise.
