- Sep 19, 2007
420HC.
It has done very well for Gerber. Strong stuff if you treat it correctly.
sure you're not thinking about Buck? I've had terrible luck with gerbers in 420.
420HC.
Condor uses 420HC in their stainless machetes as well. Shows you it can take a good edge and still be plenty impact resistant! :thumbup:
The last time I checked 440C and 1095 had been around a lot longer than RAT or Rowen. Anyone knows that. Rowen, however, does have some proprietary heat treat processes for particular steels.
Amen. 420 is near perfect machete steel. It is very tough.
I will never understand all the hate for 400 series steels. I have used 420, 420J2, 420HC, 440C, 440A (yes, even the 440A in my Ka-Bar Next Gen is great in my book), etc etc etc. Guess what... they all work. In fact, some of them work quite well. They sharpen easily enough that they aren't a pain to work with in the field. They hold edges through a reasonable amount of work. The 420 steels are VERY corrosion resistant. They seem to take a polished, refined edge well. They are tough. I actually LIKE 400 series steels a lot more than most stainless steels.
When I look at the ESEE line and their use of 1095, I think a 400 series steel makes total sense for when they branch into some stainless offerings. In fact, I would have been surprised if they didn't go with something like 440C.
If you don't like 440C, don't buy a 440C ESEE.
As far as 400ss MY only bad experiance with them is 420HC. They chip very easy. IME. When cutting manila/nylon rope if theres and metal wire in there they will chip. I use Vg10 , 154cm no problem. I have a 440c but haven't fouled it up yet. Seems hard. 420 IME would be to soft for my use. I use my knives for work. My reason I hope they use a harder steel. Cutting flesh maynot matter. It's all how you apply the knife for your needs.
A lot of this goes back to Rowen's shop, availability of materials, types of heat treat required and a lot of other things figured into the mix. Like I said, 440C works. Has worked for years. It's a great steel just like 1095 Carbon is. We're known for simplicty and what works.
That's the reason I said I don't like ATS34....because 154 was mentioned. Why do I not like it? I have found no real advantages with it over 440C. When we first got on this SS research thing I started using various steels. I've had several knives in ATS34 that had chipping problems and just seemed to be over-hyped SS, IMO.
mabe the 420 was too hard, not too soft.
I am just going by my Gator clip point folder that I have been abusing almost daily since I picked it up back in '96 and more recently my brother's LMF II which has seen its own share of horrors.sure you're not thinking about Buck? I've had terrible luck with gerbers in 420.
I might like to see something like 12C27 or AEB-L used, because they don't usually have the large primary carbides that 440C can have, leading to edge tearout, carbide banding, brittleness, etc. But if Rowen has a lot of experience with 440C, and has a good heat treatment recipe for it, then that's what they should stick with for now. They've certainly proven that they know what they're doing with 1095. So I'd rather get an Izula in 440C, and compare it to my 1095 versions, before complaining about the alloy chosen. Besides, maybe they'll sell them shiny and naked, and save a lot of people time and money stripping them.![]()
Could be. But I had a few different brands 420hc they will chip or roll. Maybe good steel but they chip easy for me. They are easy to sharpen or repair. Buy my other knifes just stop when the hit wire and don't chip. Guess if your using them for fishing or something they will work well
Now see, THAT is what I don't understand. You're FAR from the first person I've heard say this. Yet I've never experienced anything like this from 440C from several different makers. And they tend to see the most use, because they tend to be cheaper so I beat them harder. In my experience, 440C has sharpened better, held its edge just as long, and cut as well as any stainless steel I've tried except VG-10, and better than most, including ATS-34, ATS-55, and the old CPM-440V (S60V?).
440C has a bad reputation that in my experience does not bear out.
Some of that could be a function of the grind on certain knives. I was using a Dozier designed folder from Ka-Bar, which has a thin hollow grind on it, and when it ran into some wire during a cut, it totally rolled. My point is that the steel is not the only contributer for good or for bad. The grind matters a lot.
