I happen to think that Cobalt's thread interpreting your numbers is the single-most enlightening post in this thread.
I wonder if the disparaging remarks about Cobalt's positive contribution to this thread would have (could have) been made had the same thing been said by someone other than a well-known Busse fan. Moreover, I don't recall anyone saying that Cobalt is a fan of Busse knives only.
So much for no hidden agenda!
I did post everything on this page:wow, some real creative math at work here. Vassili, you should post the actual measurements for each run instead of just the median value. I wonder how much importance the infiholics will place on a 10 gram difference in initial sharpness when they see it comes from 21 cuts with a, what, 50 gram spread?
Spread is result of tools precision not quality of edge (which I purify using statistic - median).
You can't interpret results that way. You can say that this test is not completely accurate because they didn't start out at the same level of sharpness, but only through statistical nonsense can you say that INFI performed "83% better than 420HC," unldess you're just making sarcasic comments, in which case I don't think you're adding anything to the discussion.
I am not discounting the original sharpness, I am telling you that you cannot interpret based on percentages from initial sharpness. HoB gave a nice lengthy post about why.Larrin as usuall you are incorrect. The results have to be interpreted as a matter of difference from start to finish if yu want to discount the initial sharpness, if you could get away from your hidden agenda you would realize that. The way I interpreted the results is correct and the only logical way.
Noz,
I know how hard this work is, and how long it takes. I'm doing a similar test with D2 and CPM D2, and it's *much* more work than I thought it would be. I aggrevated an old elbow injury, so had to take a break for a while.
I'll be posting the raw data also, so people can draw whatever conclusions they like, but the results will be posted on Cliff's site. I'll let you know when I'm done if you are interested.
I think these two statements really show the heart of the issue here. I tried to address this in my previous post. In order to give percentages you need an absolute point of reference and the initial sharpness is not one. It is the same mistake to say that 50g is twice as sharp as 100g as it is to say that the temperature increased by 100% when the temperature was raised from 50F to 100F. Let's examine this a bit more Cobalt's argument would be that you take a pot of water at 40F and heat it to 120F and a second at 50F and heat it to 100F. You then proceed to claim that the first pot is 300% hotter than it was before and the second is 200% hotter, a difference of 100%. Without wanting to step on anybodies toes but the truth is that this line of argument is complete and utter nonsense as the Fahrenheit scale happens to be about as arbitrary a scale as one could envision. In truth, the first pot was raised from 278K (K stands for Kelvin which is measured to the absolute 0 temperature) to 320K, a mere 15%, and the second from 283K to 310K, by 10%. Hence the difference of the temperature increase between the two pots is a mere 5%.
For sharpness, value of absolute sharpness is practically not really possible to define, as towards 0g the scale would get hopelessly nonlinear, but in principle, it would be possible to use 0g as point of reference. Far more practical is it to use absolute bluntness as reference. My guess is that the thread, that Vassili is using, breaks at about 1.5kg (this corresponds to the strength of the polythread that I started testing on) on a completely unsharpened edge. So 30g is actually 2% bluntness while 40g represents 2.7% bluntness. This is a much more illustrative number, as shows, that both are bloody damn sharp with little difference between them. Now, after so-and-so many cuts the 30g blade dulls to 120g while the 40g blade dulls to 100g, or 8% and 6.7% of complete bluntness. So the first dulled by 6% while the second dulled by 4%....a difference of wopping 2%!!!!!
These numbers represent much more closely how the dulling is experienced in practice. They also explain why this test has changed Nozh's steel-snob attitude....(I still have my doubts.....about this change of attitude, I mean, not about his numbers; I would bet a good deal of money that he will continue to lust after the latest and greatest steel....but then, who doesn't
I haven't said anything about INFI being better or worse than 420HC, and I haven't discounted any maker's work or choice in steel. The only one with an agenda here is you. You're trying to show by your interpretation of data that INFI is the better steel. Regardless of whether the data shows what you are saying it does, doesn't say that it is better anyway. INFI is a good steel. It is a good choice for Busse's designs, purpose, and customer base. I have no problem with it.
I don't necessarily think 420HC or INFI are "better" than the other. Different steels for different applications.
