Is the heat treat on a given test knife of any concern?
In asking this I do not doubt that this testing is valuable, but that it may not answer the questions some might want answered. For example I would guess the testing will not say which steel is "better" than another steel, but rather something along the lines of Vassili's specific knife X tested better than his knife Y.
Maybe if lots of people started contributing test results on steels prepared in various ways then some interesting consistencies might surface. That would be cool!
Vassili, good work! :thumbup:
db & Vassili, I am not concerned with the thread cutting or how much force to cut the rope- couldn't a thicker edge maintain itself better? -or a thinner edge cut better in spite of dulling?
I don't know which way this would go, I just think it's a variable that should be eliminated. If you're wanting to compare edge retention of the steels, the only difference should be the steels.
I imagine you think you're only measuring the very edge so only the angle matters, but the thickness of the edge, and even of the blade, could be skewing your results by the effect it may have during the rope cutting, even if it doesn't effect the thread.
Vassili, given your above post about the "crazy evolution" of INFI and looking over your results table I strongly suspect that your method of determining sharpness is somehow inconsistent. Your results for ATS-34 look consistent, a gradual dulling of the blade as more cuts are made. But for both INFI and 420 the results gyrate suspiciously. This just doesn't add up. I know you are taking the median of 20 tests, but nevertheless it seems that there are variances in the test taking, perhaps 20 tests done when you are fresh are not equivalent to 20 tests done when you are tired. I said this before, I think you really need to run these tests in a side by side manner. I'm not trying to be critical, I'm just seriously starting to doubt the accuracy of your results.
Cobalt: Yawn :yawn:. How about YOU do some graphing, instead of seeing things at one glance. Or better yet, you do some of your own testing. If you did, maybe you would realize that there are no landslides in Nozh's data set.
ScrapYardKnives DumpsterMutt SR77 (S7) - 50
Microtech Currahee D2 - 60
Kiku Matsuda Tanto II OU31 - 60
Spyderco Military BG42 - 60
Spyderco Endura ZDP189 - 60
J.P.Holmes CPM 10V - 70
Dozier KS7 D2 - 70
Swamp Rat HRLM SR101 (52100) - 80
Busse Meaner Street Red INFI - 80
Kershaw JYD Sandvic 13C26- 90
Kershaw Cyclone ZDP189 - 90
Fallkniven P SGPS- 90
Busse BA INFI - 100 (inspected by #4)
Buck 110 CPM154 - 110
Mission MPK-S -130
Swamp Rat Mini UM SR101 (52100) - 130
Busse BA INFI - 130
A digital scale would definitely make all of this more accurate.
The 420 also seems to have a "self-sharpening" capability as well going from 90 to 70 between cuts 40 and 45. Has anyone checked for nanobots.![]()
