nozh2002: I watched your video and saw you dropped the knife on the thread and cut it and your doing it by hand. If your using different blades of different weight how does this affect the out come of the test ?
How do you know you have the exact same amount of tension on the thread every time ?
And how do you limit the angle of the knife so the edge is being placed on the thread is completely the same every time and not cutting the thread at an angle ?
An will this affect the outcome of the test with many resets. and human, blade weight, and the exact same portion of the edge being used every single time ?
I have been making a machine to cut rope and have been struggling with a design so different blade weighs do not go against the scale.
The photo is an early prototype the new one is about 200 parts at the moment.
In the photo of the machine I have a counter weight system to set the knife
to zero weight. The knife is loaded under very light spring weight against the rope. About 1 pound. then the digital scale is zeroed out. The cutting stroke is set at whatever length I desire and is continuously repleted and controlled
by a computer for however many cuts I chose to make and the exact same edge portion is run over the rope.
I'm trying to remove all human error out of the equation
Thanks
nozh2002: I see... Thanks and yes tests that people can recreate
themselves cheap and easy is all ways good.
I think it is great what PghMitchS02 did. This is some point of view. I respect it. He may be wrong, may be not - we may discuss it.
HH: Perhaps some don't also realize how crazy sharp 30-40g really is.
Nozh: I do not think that it is correct to say that 50g edge "twice sharper" then 100g edge.
I think these two statements really show the heart of the issue here. I tried to address this in my previous post. In order to give percentages you need an absolute point of reference and the initial sharpness is not one. It is the same mistake to say that 50g is twice as sharp as 100g as it is to say that the temperature increased by 100% when the temperature was raised from 50F to 100F. Let's examine this a bit more Cobalt's argument would be that you take a pot of water at 40F and heat it to 120F and a second at 50F and heat it to 100F. You then proceed to claim that the first pot is 300% hotter than it was before and the second is 200% hotter, a difference of 100%. Without wanting to step on anybodies toes but the truth is that this line of argument is complete and utter nonsense as the Fahrenheit scale happens to be about as arbitrary a scale as one could envision. In truth, the first pot was raised from 278K (K stands for Kelvin which is measured to the absolute 0 temperature) to 320K, a mere 15%, and the second from 283K to 310K, by 10%. Hence the difference of the temperature increase between the two pots is a mere 5%.
For sharpness, value of absolute sharpness is practically not really possible to define, as towards 0g the scale would get hopelessly nonlinear, but in principle, it would be possible to use 0g as point of reference. Far more practical is it to use absolute bluntness as reference. My guess is that the thread, that Vassili is using, breaks at about 1.5kg (this corresponds to the strength of the polythread that I started testing on) on a completely unsharpened edge. So 30g is actually 2% bluntness while 40g represents 2.7% bluntness. This is a much more illustrative number, as shows, that both are bloody damn sharp with little difference between them. Now, after so-and-so many cuts the 30g blade dulls to 120g while the 40g blade dulls to 100g, or 8% and 6.7% of complete bluntness. So the first dulled by 6% while the second dulled by 4%....[B]a difference of wopping 2%[/B]!!!!!
These numbers represent much more closely how the dulling is experienced in practice. They also explain why this test has changed Nozh's steel-snob attitude....(I still have my doubts.....about this change of attitude, I mean, not about his numbers; I would bet a good deal of money that he will continue to lust after the latest and greatest steel....but then, who doesn't
So the first dulled by 6% while the second dulled by 4%....a difference of wopping 2%!!!!!
Taking my own suggestion in the last post I made, here's the table:
__________________________________________________________________
% Increase Over Cut 0
Cut INFI 420 ATS INFI 420 ATS
0 40 30 40
1 60 50 60
2 70 50 70
3 70 60 70
4 80 50 70
5 80 60 70
6 80 60 70
7 --- 70 80
8 80 80 80
9 --- 70 80
10 70 70 80 75.00% 133.33% 100.00%
12 80 70 80
15 80 80 90
20 80 70 90 100.00% 133.33% 125.00%
25 80 80 90 100.00% 166.67% 125.00%
30 90 80 90
35 90 80 90
40 90 90 90
45 90 70 90
50 80 80 90 100.00% 166.67% 125.00%
60 90 70 90
70 --- 80 90 166.67% 125.00%
80 100 80 90 150.00% 166.67% 125.00%
90 110 80 ---
100 110 80 90 175.00% 166.67% 125.00%
110 110 80 90
120 110 90 90
130 110 90
140 100 80
150 110 90 175.00% 200.00%
160 110 100
170 120 110
180 120 110
190 120 110
200 130 100 225.00% 233.33%
210 120 110
220 130 110
230 110 ---
240 110 130
250 110 130 175.00% 333.33%
260 110 130
270 110 140
280 110 130
300 110 140 175.00% 366.67%
320 110 140
340 120 150 200.00% 400.00%
360 120 140 200.00% 366.67%
380 120 140
400 120 140 200.00% 366.67%
_____________________________________________________________________
I did not bother with comparing all the cut data, but I think this shows the trends well enough.
Actually the difference is 33%, not 2%. In computing the percentage difference, you subtract the second data point from the first and divide that difference by the first data point. In your example 6 minus 4 is 2, 2 divided by 6 is one third or 33.33%, so there was 33.33% less dulling in your example.
probably it is due to ATS-34 fine grain structure.
Ummm, huh? ATS-34 isn't exactly famous for a fine grain structure....?![]()
