I love the tests Vassili,
But I don't see how they can be accurate without having identical knives made of the two steels being tested?
Of course if you looking for full aspects of steel performance you need same knives with different steels, but there are no any!
Spyderco Military, available in S30V, BG-42, and CPMD2 right now.
Benchmade mini-Griptilian, available in 154CM and D2 right now, and you could probably find it in 440C (S30V version has a different edge geometry).
Buck 110, available in 420HC, ATS-34, BG-42, and damascus right now.
Probably others as well.
the tests have varied. I think the most common is slicing the rope and then push cutting another material to check loss of sharpness. I recall objections to the D2 slicing tests because it was being done by hand, the length of slice and amount of force applied was considered by some to be too variant for such a light media to cut.
I wish more people would try the slicing sharpness test I did in that comparison to see what kind of results they get, or maybe venture out and try some of their own slicing sharpness tests. I know my results tracked well with the loss of cleaness of the rope cut, shaving, cutting newsprint, ect., but of course anything done by hand and eye like that is subject to human error. In fact, every portion of all of this testing is subject to human error, it is just a matter of how significant is that error. Doing multiple runs and measurements per sharpness point definately help to smooth things out, but there will always be human error involved. I like the push cutting sharpness testing with thread on scales, but I do think there is a lot of merit to testing the slicing sharpness also, as it is true that some edges that won't pushcut very well will slice very well. It just seems harder to come up with a consistent and repeatable test for the slicing sharpness.
Mike
I think, what is really the point here is to quantify perceptible loss of sharpness and the thread and scale is capable of quite a bit more. It needs a very skilled hand to detect a difference in sharpness between an edge that measures 30g or 40g or between one that measures 120g or 130g (in fact I would suspect most would not be able to tell them apart) and only when they are sharpened to the same finish. So the scale offers already a precision that already exceeds the practical necessity.
I find it useless to call for greater precision if you can already not tell the results apart in practice anyway. My point is, if you can not tell in practice, without a scale, whether an edge dulled to 120g or 130g, because they both will feel the same to you when cutting something or when "feeling the edge", then why do you need a higher precision measurement? When you look at Nozh's data, you have to realize that those fluctuations in the data are well below what you would notice without thread and scale. Any knifenut will be able to tell a difference between an edge that comes in around 30 or 40ish and one that is 100+, but to get hung up on the 10g fluctuations is really not helping any, me thinks. The thread cutting test is surprisingly reliable and it is able to detect variations that are below what even a skill user would notice in regular use. Just look at Nozh's FF review. The threadcutting is easily capable of verifying the users impression of the edge.
what do you mean by hard work and heavy load, isn't the rope cutting with about the same amount of force since the thread is?
I mean that since the thread is still being cut at 130g, that means the knife is still plenty sharp, so the rope should still be cut at lower force. I can see how the 420HC at 260g on the thread would mean a lot of force to cut through the rope, but the INFI only went from 110g to 130g.
800 cuts is hard work and heavy load at least to my wrist and elbow... It hurts!
Thanks, Vassili.
