I am happy to see that you haven't lost your good humor. I prefer to be wrong than see a thread like this glide off into sillyness. As long as I am learning something, I don't mind being wrong.LOL. It appears my quick analysis at a glance from a hotel room was more accurate than your attempt at it in tons of long paragraphs.![]()
Seems like we are all on the same page now.at what gram weight would you consider a knife barely able to cut. I think this is crucial in your test. There is no way to quantify and compare the results unless you have a gram point at which a blade can barely cut thread, which would be the same point for all knives.
Excellent point!After hundreds of rope cuts, his knives are about the same level as most quality factory fresh blades.
I have been wondering how the grit at which the blade is finished at affects the thread cutting. I am pretty sure that it doesn't matter much if you finish at 4000 or 8000#. But are there differences between really coarse edges and really fine edges. Does for example barely shaving edge at 8000# come in at 120g and one at 120# at 190g for example, or vice versa? I have no answer, I have just started to work with coarse edges, but I could see that on the really coarse finish the individual strands of the thread will find spots between the "teeth" and either will find flat (blunt spots) and increase the force or will get wedged in between the teeth which might decrease the force.I had a shaving edge with a median of 190g, from 120 grit.
Well, I think in the extrems at least this question is pretty easy to answer. When you test the strength of the thread with a plastic ruler which has pretty rounded edges, you can really see the strands fibers of the thread, so the thread is rather torn than cut. The force component that makes the thread fail is essentially all along the thread. The thread would likely fail in the same way if you would hang a weight from it. When cutting the thread, the strands are terminated pretty sharply. The thread seem to fail largly due to a tranverse force component. But I agree with you that the question where cutting starts and tearing ends is probably largely philosophical.This also reminds me when I asked what cutting was anyway, and no one had a great answer. The thread parts at 1.5kg, and it parts at 30g. When is it no longer being 'cut'.
You can't interpret results that way. You can say that this test is not completely accurate because they didn't start out at the same level of sharpness, but only through statistical nonsense can you say that INFI performed "83% better than 420HC," unldess you're just making sarcasic comments, in which case I don't think you're adding anything to the discussion.
I look forward to seeing your results if and when you test D2, that steel in my personal experience behaves curiously. Not matter how fine a grit I use to sharpen it, it still always feels very toothy. It then holds its toothy edge for quite awhile, but when it starts to dull it seems to get really dull very very quickly. But then this is based solely upon my experience using it, not formally testing it.
But if you look at the pictures on the previouce posts you may see why. It has huge carbides which may form this teeth you feeling. And they may stand while surrounding iron wear out - and this will keep it toothy, but eventually they all fall out and expose not sharpened rounded carbides...
Think about old castle stone wall sharpened and then wearing out...
Of coures this is just hypothesis but I will eventually test D2 - I have Dozier as well as Microtech Currahee.
Thanks, Vassili.
I didn't try to get it any sharper, that was what I got right after I took the bur off
It looks like he's cutting the rope with a push cut to me.Thanks for the results, Noz.
My understanding is that Noz is testing thread with a push, but previous thread tests I've seen are measuring it with a slicing motion. Is everyone in agreement that a test that uses a slicing motion on thread is a test for sharpness? I was under the impression that those thread tests were measuring "slicing ability"? Many variables are added with the addition of a slice to the thread test, and I think this push cut version would be more repeatable from tester to tester.
This same test method - measuring (true or push cut) sharpness with the wear or dulling caused by slicing - was vociferously objected to with some previous test results posted here, if you recall. No objections here, but thought it was worth mentioning, when there is opinion out there that a knife that slices like a mother can get poor results with a push cut test. For this type of knife/steel may not perform well in this test, or just never reach the sharpness levels of other knife/steels will reach using this test (yet still slice like a mother). something to consider, anyways.
All the statistical questions are to me best answered by looking at a good graph of the results. In my opinion trends and correlation are much easier to see that way then the numerous statistical analyzations that are possible.
