Steel is steel is steel is steel...
It seems that some people want new steel to serve as an "excuse" to buy more knives.
I myself have the opposite desire: I want simplification -- I want to not have to wonder and worry that there's a new better one out there that I must have. I want just a small number of knives I love entirely and trust implicitly to handle the job.
I would rather find my reason to buy more knives residing in the fact that new designs and features come out, rather than just new steels. New steels, to me, are boring. It's the innovative new locks, new blade geometries, etc. that thrill me -- not the subtle and barely noticeable tweaks on already-high-performance steels.
-Jeffrey
peacefuljeffrey said:
See, a post like this just lets me know that I do NOT know enough or follow closely enough all the things you need to be aware of to make "the right choice" of steel for your knives.
You can avoid poor choices with fairly broad rules, in general the further you try to go the harder it gets because you end up with a bunch of things competing against each other and you have to decide which ones are more important and to what extent. As well in general, small refinements take way more work than the large initial benefits.
Well, it just appears to me that there haven't been such worthy differences found.
A lot of the advances are not for you and I but for makers. Steels which make it easier for them to do the heat treating or improve the finish. CPM-154CM for example is mainly for knifemakers who found S30V to difficult to work with, not that it makes a better knife for the guy cutting things.
Many times the advancements are trying to blend properties, 3V for example was an attempt to improve on the wear resistance of D2 and the toughness of A2 and do it all in one steel. S30V was origionally promoted as a stainless steel with tool steel toughness.
BG-42 combines the properties of high speed and stainless steels together. CPM REX 121 is essentially a carbide replacement for toughness failures, 72 HRC. The japanese are now working on high toughness powder high speed steels.
I want to know in a chart-and-graph sense just where improvements have been made in exactly what facets of knife performance, and also what tradeoffs have been made and what may have been compromised in the switch.
That would be useful indeed, it is pretty easy to find for tool steels, not so much for stainless. This is a complex question though, even if you narrow it down to edge retention and can't be reduced as trivial as is often claimed. Phil Wilson, R.J. Martin, Jimmy Fikes, Sal Glesser, Kevin Cashen, Jerry Busse, and Ray Kirk are all solid guys to talk to about knives and steel, a very high knowledge/hype ratio. Swordforums has a very informative forum on metallurgy, it does get complicated though, you need to have a basic background to follow some of the more technical discussions, a basic text like Allen covers most of it.
What I was saying in that post is that short of a gain of say 10 RC points in a very corrosion-resistant knife steel, why are we tinkering around so very much and being so incredibly fickle.
Corrosion resistance stainless steels at near maximum martensite hardnesshave been around for a very long time, ATS-34 can reach 65 HRC, most stainless steel are way under hardened because it requires high temperature austenization, aggressive quenchs and/or cold treatments.
When I still see knives in new steels listed at Rc 58 when I know I've seen others in older steels that claimed to be hardened to 60 or 62, I ask why we even switched. Can an improved, new steel be better at taking and holding an edge even despite a lower-than-the-last time Rockwell hardness?
Yes and no. Ease of sharpening depends on grain size, carbide distribution and hardness. Edge retention depends on strength and wear resistance as well as impact toughness. A steel can have greater wear resistance at 58 HRC than another at 59 HRC but have lower toughness and strength so it will be superior for some cutting and not others.
You can have a steel which works very well at a high angle (say 20) but then breaks apart at a lower angle (say 10) and then another steel which takes the lower angle readily and is now vastly ahead in a direct comparison. Now which one do you say has better edge retention? This is still just considering one medium cut in one manner and it can all change if you switch materials, method and grit finishes.
-Cliff
-Jeffrey
That's cool also. that also adds depth. Some could care less about design and features, others could care less about locks. That's one of the beauties of the knife world is that it offers more in whatever is your fancy.
sal
Steel is one of the knife property overall design is other property, usability etc.
I like RosArms knives for their great design both beautifull and usefull - even they have 440C kind of steel - best Soviet stainless - nothing like ZDP-189. But ergonomic and beauty is what impress me!
Steel is also attract my attention - I am very impressed with SRS-15 steel on G-Sakai Bosen Enkuto and Spyderco ZDP-189 on Callipso Jr.
And Kershaw-Onion mechanical things also impress me - studlock and Speed safe...
I think some people may pay attention to one thing and some to another - as usual for human nature. Somebody like look, somebody performance, somebody legend behind or flawiour of super special underwater paradrupers tactical. Nothing wrong with this - we are all humans equally inperfect.
Thanks, Vassili.
DGG said:
Peaceful-
Don't worry about it! Be Happy!
In about 25 years we won't even be using steel knives. By then lasers will be perfected to the point that we carry laser knives instead of these clunky steel things we have today. Laser knives will be powered by small batteries with very long life. Laser knives will have a sensor to warn you before you cut something that is alive. They already are using such knives in the medical field. Laser knives will not be light sabers. They will only have a blade length of about 3.5 inches. They will never need to be sharpened and they will make incredibly accurate and fine cuts. You will be able to pinpoint the beginning and end of the cut, push the button, and the laser will connect the points and make the cut.
Anyone not agree with this forecast? Why?
Here are some rather gory pictures showing laser knives in action. Please don't click on this link if you have a weak stomach.
http://www.clinicon.com/diamondlaser.html
You can't pry with a laser.:)
DGG said:
Peaceful-
1 - the need for everyone in the vicinity to put on protective glasses when you use your "knife"
2 - "Darn! Every time I need to cut something, the batteries are dead!"
3 - "Oh no! My refund check is on fire! I wish I opened this envelope with an old fashioned steel knife!"
4 - when you break a little bit of the tip off prying open a paint can lid, you can't just grind a new tip on.
lol
5. The "authorities" will turn off your knives with a remote.
6. Uh Oh, I set the "blade" too long and cut the table.
7. Ouch, I sat on the switch my knife opened in my pocket. (just like the old days ;) )
8. Spreading peanut butter is tough, keeps melting.
9. Use "Lasitech". Keeps your ruby from getting gummed up.
sal
What is better ?
Mauser custom'06
700 Remington custom '06
788 Custom '06
Pre 64 Winchester custom '06
Kimber
Savage
Bill Bob Thornton ?
It's all about the craftsman and what he is comfortable with working with.
BTW The 788 has the fastest lock time of any rifle other than the 541... :cool:
What is better ?
Mauser custom'06
788 Custom '06
Kimber
Savage
Bill Bob Thornton ?
Well now..... that is just plain silly to pose this question.... we all know that any of the forementioned firearms are far superior to Billy Bob Thornton...c'mon! and by the way... i am betting Angelina Jolie would agree!
:D :D :D :D :D
Ifun you havbe a piece of 5160 send it to Blinker ( Robert Hankins)
Ifun you have a slab of D2 send it to Dozzzier
Ifun you have a chunk of 154 send it to Wharton..
Get the picture ?
You are a cocky as I am :cool: :cool: :cool:
The fewer the occasions to USE something, the more of the things you'll buy.
If we were busy skinning food and stabbing Indians, we'd probly not worry about which steel was best.
Steel is steel, is steel, is steel
and.....
It beats the heck outta bronze
:D
Beef is beef. Sure, some cuts are better than others, but it is only part of the whole 'meal'
It is what you do with the whole 'meal' (or knife) that really counts.
Bad cooking (heat treat) could ruin it.
Bad seasoning (geometry) could ruin it.
Bad presentation (fit n' finish) could make it less than desireable.
Gotta go by the whole package, not just an ingredient.
Now I want a Venison Tenderloin, that I shot with a Remington 788 in .30/.30, brought to my table by Angelina Jolie and carved with Randall steak knives.
I told myself I would not get into another steel debate, but...The sad truth is that any steel on current production knives will satisfy the average consumer. I have trashed Case, Buck and others for their steel but have read in the same forums how good each one is. The average citizen will not be moved by a knife made from a "super" steel versus a production steel. Just won't happen and I am proud for not taking on someone in any steel discussion...
steel is steel is steel......
The "acid" test for me, if possible, without knowing the steel, does the knife work (for me) as intended.....
That's why I've EDC a Victorinox SAK for well over 24 years - and for a long time the SAK steel was somewhat of a "mystery" -
but I didn't really care - even when some derided it saying it was soft and "junk" - it really worked for me - and I could get the SAK blade to be really sharp - that's cutting THROUGH things - not just shaving, slicing free hanging paper....
However using the unknown steel "test" I can tell, see and feel the difference between something like 420J2 and a more "respectable" steel - like even 440A - the 420J2 will tend to fold-over at the edge as opposed to forming a burr that's easily knocked off - preventing me getting a clean crisp edge - without some extra careful work - whereas I did not have this problem with the Vic SAK steel (even if it is "soft")........
Getting back to the unknown steel criteria -
for years Buck had a very fine reputation for really sharp knives - with steel that was notoriously HARD to sharpen
- with much better availability of information we found that Buck used 425M and later 420HC..... not exactly SUPER steels -
so now that we know - are all those early Bucks "junk"? :eek:
Another good example is the G-10 S30V Leek (textured/matte version) I recently reviewed (linked) - the S30V steel blade did NOT cut as well as the more common-garden variety 440A steel blades on a simple cardboard cutting test..... yes, of course, this is easily remedied by re-profiling/sharpening the S30V blade -
but this is the point -
"better" steel does NOT always make a better knife......
sometimes, even when they are the "same" knife......
Vincent
http://UnknownVT2006.cjb.net/
http://UnknownVT2005.cjb.net/
http://UnknownVT.cjb.net/
http://UnknownVincent.cjb.net/
OK, I didn't read every reply to the OP, so apologies if this point's been made, but really, as long as the blade is sharp when you need it to be, does it matter what steel was used? I mean, if the knife's not sharp, sharpen it! If it is, all the better. Personally, I'm getting into knives pretty good, but I've decided that my buying decisions are based on design and feature set, NOT steel. Call me a philistine, but there it is. Just my $.02
UnknownVT said:
...are all those early Bucks "junk"?
In some regard yes you would expect as advances were made then perspectives change. I started doing numerical analysis on a 386, if I tried to use the same computer to work with recent data it would simply not be possible. I can do things now I could not back then and any new computer which ran at the computing capacity of that 386 would indeed be regarded as junk though of course that was not how I looked at it back then. It was a hell of an improvement over the Tandy 128 I had been using personally which had 128K of memory and who would ever need more than that (blew my old Vic 20 away).
Take any custom knifemaker and look at the knives they first made and the ones they make 20 years later. You would assume that after a couple of dozen of years their knives would be a lot better which directly means the initial ones were a lot worse. Phil Wilson noted this when I discussed knives with him years ago. He didn't say his initial knives were junk, but he was clear that after talking with Boye it had a large influence on how he ground blades and a pretty radical shift in performance. He now simply has much higher standards. How long have SAK's been made to the same spec's?
Steel defines limits on performance, heat treatment realizes the potential, geometry applies the potential to reality. All of these need to be there for optimal performance and if all of them are not then it fails. You can't get corrosion resistance out of L6 no matter how you heat treat it and you can't get high wear resistance out of 1045 as there are simply no carbides. I think the SAK steel is a pretty solid choice for what the blades are meant to do and the blades cut fairly well given thier price point. I think they could be improved with oil/cold, but there are then cost issues.
jhansman said:
...as long as the blade is sharp when you need it to be, does it matter what steel was used?
You can't sharpen any steel to any profile thus the cutting ability is influenced by the ability of the steel. Some can't even be sharpened at certain profiles, the edge just breaks apart.
-Cliff
-Cliff
Fair enough, but are steels of that quality used in knives of any reputation at all? I'd expect that lack of quality from some cheapie I got at Big 5 for $10, but not from the blades I've bought so far. I'm not saying buy just any knife of any steel; I just trust that the better know manufacturers use a variety of steels that their knives will take and hold an edge. Why would they do otherwise?
Many years ago, long before Bladeforums, Alvin Johnston ground ATS-34 blades heat treated by Paul Bos (who is fairly well regarded as a heat treater) to very thin profiles and the edge had very low edge retention and not even got very sharp as it was too coarse a steel (and too soft compared to what it was referenced against). At the time ATS-34 was the "hot" stainless steel used by many well respected custom knifemakers.
Sodak recently has been reprofiling blades to similar profiles and noticing differences in the behavior of steels, problems with D2 for example which has one of the most coarse carbides of the tool steels. Tool steels are all generally made to high tolerances, but the grain and carbide size, toughness, strength, and wear resistance can vary massively from one steel to another, not even in the same magnitude.
-Cliff
