thanks grease man.
too bad we don't have more makers opinions on the subject. i hold their opinion to a higher regard.
I made my first knife at 12 years old. I was taught to make knives by my Stepfather, a retired US Marine. I then served for 14 years in the US Marine Corps. During that service I had the opportunity to learn more blade smithing from local knife makers in remote places of the world. The knives I make were designed to withstand military service. IE: if you need to dig a hole, then you use it to dig a hole, if you need to pry a crate opened then do it. I don't make knives 'professionally' The job I have pays to well for me to walk away from, But, I make around 5 to 10 knives, a bunch of arrowheads, an axe or tomahawk and a spear or two every year.
OK I tooted my own horn so I feel better.
So to the point. Here we are still beating up the stick verses full tangs issue. True stick tangs are actually a rarity with tapered tangs (like the Mora's I have taken apart) and hidden tangs and a bunch of variants of those being more common. BUT even that skinny Little stick has an amount of strength that your not likely to break.
Here's an example that I have tried to make Before. A 40d nail is 3/16" thick and 5" long, made from the lowest grade of steel usual. I have bent about a thousand of these nails with my hands, ( I used to compete in strength competitions now I just bend then to amuse my grandchildren) A 3/16" X 5" nail or hot rolled steel of the same size, if clamped in a vice at the half way point and a scale put on the other end will take approximately 160lbs to bend to 45 degrees. Add to that any thing you add on ( the handle material) greatly increases the overall strength. A 3/16" round tang would be the worst possible choice for a tang. Just trying to keep the handle from turning would be a problem so a square tang 3/16" x 3/16" x 5 is the obvious improvement at least to keep the material from turning on the tang. On to that add that there is more mass in the 3/16" square than the round. My simple shop test shows nearly 50% increase in strength in square over round. Most knives have substantially more mass in there tang or start out at nearly the width of the blade and taper back to a point ( like a Mora or a Khukuri )
There are or have been some junk knives that an unscrupulous maker welded a stick to a blade and passed it off on someone. Well you paid for junk you got junk. I don't tout the virtues of narrow tang because I think its some how magically stronger, but because it opens up more options for handle designed and material. I have a few Mule deer antler crowns that would just be a shame to cut in to scales. so I'll make a hidden tang with a steel buttcap, so you could hammer your heart out your just not going to break this knife.
I don't have a vested interest in ether way. I make my knives for my self and a few close friends. I just think to many people have been sold a bill of goods that has no merit.
