- Oct 3, 1998
Mission accomplished, then. We've been orchestrating this entire discussion in order to get you personally to buy more knives
The Cuda Maxx I just bought has an Integral lock. Ralph has been making such locks for a long time and this one locks up tight, no play in any direction and the bar engages the tang halfway, under heavy cutting it moves towards 3/4 engagement. However it is trivial to cause the lock to disengage by torquing the handle. I chopped the Maxx into a piece of wood, batoned it a couple of times to set the blade and then twisted the knife to split the wood. This was just using wrist strength, the lock bar readily moved and the lock disengaged. This is not a problem with Ralph's knife personally, it is an issue with that type of lock in general. Integrals and liners do not have the security of lockbacks under torques.Esav Benyamin said:The two lock types as produced by these two companies are overwhelmingly reliable. The last tiny gasp of reliability will be lost in the haze of any actual real-life conditions two specific knives and their owners might face.
STR said:I can certainly agree that the liner lock and frame lock are inferior in strength to a good lock back.
Strength isn't an issue except on low end knives, the locks disengage in the vast majority of failures. However in terms of raw strength, Spyderco has tested high end integrals like the Sebenza, they didn't match let alone exceed the Spyderco lockbacks. The real problem with liner/integrals is shear cracking across the face in partial engagement, this reduces the strength massively.Wunderbar said:I believe that liner/frame locks are sometimes not as reliable but I see them as being stronger than lockbacks.
Once the lock bar starts to disengage due to torque, only a fraction can be in contact with the lock, it takes little force to crack it then, not even full wrist strain. That is a lame standard of scope of work for a heavy duty tactical folder.Chiro75 said:If you're using a folder hard enough that it shears and cracks the material of the lock, you deserve to have it break on you, in my opinion.
