Ok, so I finally did my first sharpening! Took me like an hour to get done >.> and by done I mean get over with the sequence of events I had planned in my mind.
I used wood oil at first, but soon I realized that either the stone was sucking up a lot of the oil or the oil was setting up on top of the grinding surface of the edge thereby removing oil with the grinding, leaving the stone surface dry pretty soon; I then brought out the WD-40 and it seemed to float on the stone surface longer than the wood oil. So I will most probably just use the WD-40 the next time. Because, I realized that I was not shedding much steel from the grinding when the surface was a bit dry as compared to when it had some oil / WD-40 on top, so as soon as I saw that the oil was almost all on the edges of the stone, I would dab a drop or two of the oil or a little bit of WD-40. Is that ok? How much puddle should be on the stone at all times? Is it absorbing the oil because I need to break in the stone?
Result: It did not turn out as sharp as my Victorinox, which is still pretty new and almost has the factory edge. It certainly doesn't push cut that well. And when I tested the edge by cutting a piece of paper, there were definitely some areas on the edge which caught up on the paper and did not cut clean. How do I finish these areas on the knife?
Since I didn't have the flexcut gold at the moment, I skipped the stropping part and just used the ceramic rod at the end; to get rid of the burr that might've been left? Can I do that? Or is stropping on paper / leather superior?
Thank you.
You probably didn't use the stone for long enough. It always surprises me how long a new knife takes to sharpen. The blunt patches where the paper caught may have been an indent in the edge, from uneven factory grinding. Stones are great for getting rid of these. If there are indents, when you bring up a burr, a burr will not form well on the indent. It will be smaller or non existant. A sign that you are not finished with the stone.Ok, so I finally did my first sharpening! Took me like an hour to get done >.> and by done I mean get over with the sequence of events I had planned in my mind.
Thank you.
Never press hard. Sometimes a simple magnifying glass will let you see a lot of what is happening. New cheap knives can take a lot of preparation.Also, getting a burr on the first grind seemed impossible. Maybe because I didn't know how much pressure to apply on the edge![]()
But I don't regret spending almost an hour on this because I was constantly checking the burr, edge, tip and testing it by cutting a piece of paper
I HOPE it gets easier with time; I am going to use this knife as is and re do the edge next week to see if I make any improvement or not![]()
Don't do that!!
Seriously, I'm giving you a hard time in good humor. But ceramic rods will often create burrs or make them bigger. Combination of very hard abrasive, small contact area and highly-focused pressure is a burr-making machine. To minimize burrs on ceramics, pressure and angle control really need to be fine-tuned (pressure feather-light, and never go too high with the angle).
Even without compound, I think you'd still likely do better at burr cleanup with just a bare strop. You can often do a LOT of burr cleaning with stropping on heavy cardboard as well; sort of amazing how well that can work sometimes. At the very least, it surely wouldn't exacerbate the burr issue, as a ceramic likely would.
David
As far as "to get rid of the burr that might have been left": either there is a burr, or not. If I can't feel the burr, it's not there, either the knife is sharp & ready to go or it is totally blunt & in need of stoning. We are talking about practical maintenance, not the Olympics of sharpening.
It will get easier, you will learn each time. Practice your sharpening technique on a cheap knife, but don't expect it to work perfectly. There are many reasons people buy expensive knives, including that they can have a better quality edge.
Even though I spent almost an hour on the knife, is it still not enough time? So instead of using pressure to shave the steel and create a burr, I could be using my fingers to keep the blade edge in place and let the stone do the work over time? No matter how much time it takes to create the new edge / burr? And the blunt patches are for my experimental knife, not my almost-new Victorinox one; the latter has great edge up until now.
2 questions:
Is it ok to remove the burr using a cork / piece of wood? Like, just give the blade edge one or two swipes through them?
What exactly am I looking at the edge for to know that I am done with one side of the stone? Burr formation / grinding pattern?
On cheap cutlery it should take very little time to grind a new cutting edge. You need to study how the grind pattern is being created and advancing. The formation of a burr is proof positive that you've removed enough metal to make that fresh edge. Stop and observe often. When grinding keep your fingers on the blade right opposite where it should be contacting the stone, other hand holding the handle and controlling pitch. Use a Sharpie, apply some to the edge, grind for a few passes and stop to see where you're hitting - reapply as needed. Watch more videos -
MrEdgy is Knifenut's youtube tag - has many good videos including the one Chris linked to earlier in the thread. I have some videos under
Neuman2010
Practice practice - observe often.
On a side note, is it possible to polish the knife with some household products?
If you didn't get a burr, you didn't get to the apex. Sure ,an hour is plenty of time, but if it didn't happen, there is a reason, & working out why is how you learn. I mentioned I find a magnifying glass useful, many people use Sharpie, to see what the grind is doing. From a distance, the rest of us can only guess.Even though I spent almost an hour on the knife, is it still not enough time? So instead of using pressure to shave the steel and create a burr, I could be using my fingers to keep the blade edge in place and let the stone do the work over time? No matter how much time it takes to create the new edge / burr? And the blunt patches are for my experimental knife, not my almost-new Victorinox one; the latter has great edge up until now.
Thin is better for slicing, make sure you polish the roughness off this new bevel. Most factory blades come with way too obtuse a grind, & your first task will be doing what you just described: making a wider, more acute bevel via the stone. It takes time.Thanks for your answer mtanger; I now believe that the problem may have been what you described ie not grinding the apex. Because the edge I produced was much wider than the edge that was already on it AND it was much wider than the edge on my Forschner. So I have, infact, been thinning the sides of the edge rather than grinding the edge. That combined with the fact that initially I had not kept my stone as wet as I would've liked to, MAY explain why it took me almost an hour to get one knife done.
