Deadbox - Good info, but doesn't a thin edge lead to problems when using the knife for many EDC tasks. The Spyderco Sharpmaker sharpener uses a 40 degree total wedge angle as the one most appropriate for EDC purposes, and they have sharpened many hundreds of thousands of knives. Here is a good video about how cutting edges came about and the reason the Sharpmaker works so well that may be of some interest.
dkb45
The Al Mar eagle/falcon series are super thin. They are great cutters, super slim and leight weight. And if you like it are also available in ZDP 189 steel.
Untitled by GaryWGraley, on Flickr
IMG_7165 by GaryWGraley, on FlickrI just thinned my Endura ZDP-189 behind the edge. A Norton coarse followed by fine Crystolon and a fine Norton India stone did it. I began with edge leading and trailing strokes. When my strength and patience flagged I went to longitudinal strokes to flatten and then remove the transition line of the bevel. This worked faster because a smaller portion of the blade met the stone. The scratch lines on the blade were almost eliminated by alox and silicon carbide paper 220-600 grit. A couple of deep bevel-to-spine scratches remain near the ricasso to validate the process. The printed Spyderco logo disappeared of course. I'm too wasted to get the calipers from the shop but I can feel and see the difference. The original BTE thickness was >0.030" which looked excessive though the blade cut well.Some of you guys are missing the point, it's not just the spine thickness. It's how thin the edge is directly behind the shoulder of the bevel.
Knives have a wedge cross section. The thinner the wedge the better edge. It improves the cutting ability.
The Sharpeness is still decided by the final edge angle and crispness. But it's the behind the edge thickness that really shows the cutting ability.
The BTE is more important then the stock thickness.
0.125" with a 0.005" bte will out slice a .90" at 0.025" bte
