Razorback - Knives said:Here's something to ponder while on this subject. I'm a "recreational" outdoorsman, hunt, hike, and your basic messing around in the woods so I don't have as much experience as some of you. I've been reading this thread and find it interesting all of the different opinions. Since I make mostly hunting/outdoor working knives, I would like opinions of blade grind types to go along with the rest of the ideas included here. Opinions on the best type of grind in different wilderness/survival situations. I hope I'm not hi-jacking, just adding more insight into the "survival" knife. Thanks
Scott
shpshooter said:For larger knives a convex grind is prefered as it keeps a lot of metal towards the tip which is good for chopping/battoning. However, this grind is almost impossible to properly sharpen in the field, so the flat grind is the best compromise.
Thanks Thomas, that's what I kind of figured. I'm wanting to be able to offer all three grinds so as to be able to satisfy the needs of my customers. I do flat grinds with the secondary bevel so that the blade has enough thickness to still be strong. I normally put a convex edge on a flat grind. What is the best edge for this discussion? Convex or flat? Thanks, this is very helpful.Thomas Linton said:A hollow grind is generally regarded as too weak for all 'round work. It's sort of the anti-convex grind.
Razorback - Knives said:. . . What is the best edge for this discussion? Convex or flat? Thanks, this is very helpful.
Scott
Heat treating is the only thing I outsource. It's more time and cost effective for me to outsource. I do everything else in house from profiling the blade to dying the sheath. I have my D2 and A2 blades heat and cryo treated to 58rc. Any higher then that and they become brittle for hard use. As far as prices, that depends on knife size, handle material options and if a guard is added. Prices between $185.00 and $250.00. Bigger camp/survival knives are higher.shpshooter said:I think you have a winner there, what does your heat treat on the D2 usually bring the Rc too? Also, what do they cost?![]()
