The explanation is completely wrong,
The wavelength and energy content of the photons lost are largely a function of the makeup of atoms in the body.
so the amount of irradiation produced by our bodies remains fairly constant. In other words, whether or not it is cloudy or clear or the what the elevation is has nothing to do with radiant heat loss by your body.
I also think it is a matter of chosing a good one, cheap, ultra compact ones just won't do the job.
Interesting. Kochanski says exactly the opposite. His theory is that only the true mylar ones (original style super compact space blanket)
It is a question of energy balance, lose some gain some, and the surrounding conditions strongly affect the gain part.
By letting a shallow vessel "see" only the clear sky, one can freeze water at temps markedly above freezing. Reason why deserts are cold at night.
TLM
However, gain of heat by either of the above mechanisms does not match your analogy statement in the second sentence.
I should clarify my comments on photon characteristics being related to temperature and elemental composition since at a given temperature a characteristic wavelength spectrum or set of emission lines is produced that are peculiar to the atoms making up the body. This is the quantum effect of electrons dropping into lower energy orbitals and the wavelength being produced is a function of the change in orbital that takes place. The possible valance states that can exist vary from one atom to the next and hence individual atoms produce characteristic emission lines of photons when they radiate energy. This is why we use lamps of different materials to produce different wavelength spectra even though the different types of lamps operate at relatively speaking over a fairly narrow range of temperatures. It is correct that at higher temperature more photons are produced, but this is just sort of nitpicking on my error made for a general simplicity - the assumption I made in my earlier post was that humans are largely made of the same stuff and exist at the same temperature so their IR emissions are generally the same. This is not changed by being able to see the sky!
Radiation heat loss is at maximum on clear dry nights and the higher you go the greater it gets, at 3000 m it can be double compared to sea level.
....The data I have seen shows that on clear dry nights the water freezes when ambient temp is upto 282 K.
As I said the loss is independent of the surroundings but the what one even feels on the skin is the energy balance, that is also what keeps one warm.
I'm being a little bit mean here using the quotation feature to demonstrate that you have changed your original assertion switching from clear nights causing an increase in radiation loss to clear nights being deficit in heat inputs.
Alright, now lets get back to your data that indicates water freezes at 9 degrees Celcius.
Replace the original with "net heat loss", I perfectly well know the physics involved, not much point in trying to explain it in too many words.
Not really it still freezes at 0 C, just that the conditions allow it to cool well below ambient air temp.
Water vapor is itself a IR radiator, small droplets are even better, that is the reason why the sky is colder from high up, less water between you and the cold space.
As to the windows, there is not much difference between a clear and cloudy weather, just as long as the outside is at -20 and the inside at +20. The 4th power does it's work as the windows mostly see solid matter, gases have low emissivities.
TLM
I'm a little older than you guys I suppose so my Space blanket is a Poncho and a Danish army wool blanket. Yes it's heavy, but I don't walk as far as I used to and when I stop I want to be warm and dry. Maybe age will determine some of these answers. It will be interesting to see. I have enjoyed the comments.
On water puddle freezing above zero degrees celcius we still seem to be at odds.
Actually the whole point would be that "small amount" is not that small. The temperature difference between air and the barn plays almost no difference in the regard of radiation (considering that air itself does radiate -and/or reflect- very little energy).You are in an empty barn at night. The barn walls act as black body radiators themselves so you receive IR inputs from them. Initially, the walls may be at a higher temperature than the air because of their heat capacity and absorbing sunlight. In this case, I suggest you are better off hugging the walls to attain heat by conduction then you would soaking up its IR by sitting in the center of the barn. After the barn has achieved equilibrium with the outside air then the only source of heat left would be the small amount of IR still lost from the barn because it is still above absolute zero.
Actually water will always freezing temperature will remain about 0°C. The fact air is say 9°C doesn't mean water can't be 0°C.that the actual freezing point of water is 9 degrees Celsius not zero degrees Celsius. This would be factually incorrect.
Answer would be: it's mostly about "solid angle" intercepted by clouds.The question is, do the clouds contribute more IR when you are closer to them than further away from them?
