Thanks guys for your comments. I said in the beginning that this thread would be different. I was going to show the "real" side of knife making. Sometimes we as makers have problems with the constructing of a knife but it never gets shown on forums. Some of these problems are self induced and some are out of our control.
Well as it turns out I had one of those out of my hands problems with this knife. I talked with Kevin about this and decided that instead of hiding the fact that I got a bad blade, I would show it. So here goes. I will explain below.
When I went to etch this blade I mixed up a fresh batch of acid just as I've done five hundred times before. I submerged the blade and here's what I got.
At first I thought it was o.k. In my head I wanted the pattern on the bottom half to not be quite so tight. This happens at times when you make a new pattern. You learn a bit about your layer counts and what you may need to adjust the next time you make a knife. Next time if I were to start with 5 less layers on the bottom part it would look really cool.
There was a bigger issue though. I had recently bought steel that was not from my normal supplier. The 1080 layers in the bar etched like crap. They really pitted bad. This was baffling to me. At first I thought it was my acid, so I mixed up new acid, re-sanded the blade and re-etched. Just as before the etch was terrible. The really strange thing was that there are no flaws in the steel and while grinding and hand sanding the steel look clean as can be. There were no pits. Here is a picture of the pitting.
If you will notice in the bottom of the blade where the 1080 layers are thick there is a whole bunch of pitting. The 15n20 layers look great.
What's even more strange is that I put an edge on this blade and went out and chopped a 2x4 in half with no problem. There is just something in the steel not letting it etch clean.
I have yet to figure out why this 1080 did this but I knew one thing. This blade was NOT quality enough to sell.
The reason that I know it has to be the steel is because the next day I ordered new steel from my new supplier, made a new blade over the next few days and it looked fantastic.
So here is the deal, I hope you don't mind but I have just showed you what can go really wrong. My luck is that it happened to be on a WIP thread. But I decided to go ahead and show you. I am kind of nervous about putting it our here on forums for the whole world to see but it is what it is.
So now I am going to start over. The good thing about this is that I'm going to take this opportunity to make a different Damascus pattern that will look much nicer.
I am going to post pictures of the making of this new blade but I am going to do it very quickly with less shots until I get back to where I was. I don't want to bore you with the same process you just saw. I will explain the Damascus process a bit because I want you to see how the new Damascus pattern will be made.
Please stick with me on this. I apologize to those of you that are disappointed and I hope you don't lose interest but I can assure you that you are not more disappointed than I was.
I can assure you that the new pics will produce a very satisfying result. More pics soon.
