- Jun 28, 2001
Yes, but you can always make the handles softer than the tang pin.
True, you can make the handles softer than the tang pin, but there's no need.
So in terms of hardness, the hardest would be the blade, then tang pin, and last the handle. Even with a softer handle, you'll still have to deal with the impact stress of the handle hitting the tang pin, and the tang pin transferring that stress to the blade. A softer tang pin will cushion that stress a bit to avoid stressing the blade.
I don't see any good reason to have the tang pin and handles differ in strength, they are going to be smacking each other and with a difference in strength this means something has to give or bend either the tang pin or the tang pin cups. Sure the handles and tang pin can be softer than the actual blade steel if you want more cusion from impact, but I wouldn't think that it is required. A good example of improper strength relationships between tang pin and handles are found in the cheaper balisongs, for example BM's econo line from the past. The tang pin cups in the handles of my 239 grew deeper every time I manipulated it. It only took a few months before the cups where so deep that the tang pin needed to be larger in order to lock open properly.
OK, here's where I have a problem with the way BM makes the tang pins. If you are able to rotate it, then it's not 100% tight against the blade, and there's a minute gap between the tang pin and the blade. The will cause the tang pin to bounce against the blade's tang pin hole. In my books, that's a bad design. Using the freezing method, you'll get a as perfect to 360 degree mating, with little to no gaps as possible, for maxium friction lockup, for all 3 axis (no sliding up or down, no rotation, and no wobble). Plus there would be no need to peen. Peening the tang pin into the blade, ala the Jag, causes too many issues with the handle relationship you and Eric were referring to.
I should have clarified my statement. My tang pin does not spin freely or easily, it had to be forced with a clamp. And even if you use the freezing method as you stated there is no chemical bond between the tang pin and blade steel, and I would still be able to turn because it is round, the only way to fix that is to either shape the tang pin (oval would work) or mill it out of the blade stock. That is just the nature of the beast.
I have not made my own balisong yet, so I cannot say that I am an expert on this matter. It just seems logical
