- Apr 13, 2004
Just re-read this thread. Based on what people are describing (blade bending on on one side) that doesn't sound like warping. If the blade were warping I believe it would bend on both sides. This sounds more likely milling/grinding problem than warping. Not that it matters much. But to me warping implies the whole blade is bent, curved, or cupped.
Yeah, I still say they're NOT bent/warped, and have been saying that all along:
The blade on mine looks straight to my ageing eyesight. The cutting edge is straight. The blade is flat against a straight edge on one side, but the other side isn't, it curves in slightly over the last 25mm to the tip. I didn't notice it 'til I read about the issue and looked close.
Not sure why. Matter of time before Spyderco figures it out I reckon.
^^^This describes the "problem" well. And it isn't very much. In fact, most folks would be hard-pressed to even see that slight curve on the one (obverse) side towards the end (I agree, it starts about an inch from the tip). The curve is less than a mm from flat, probably about 0.75mm (0.030") when I actually try to measure it. The blade is straight and centered on the 3 examples I have owned, and others I looked at in the factory store.
