- May 3, 2025
I get paid tomorrow and Iāll definitely blow half of it on knives im almost certainI believe you'd be fine with 4034 .
And less poor !![]()
dont go too crazy, too fast. enjoy what ya got for a bit.I get paid tomorrow and Iāll definitely blow half of it on knives im almost certaini am however getting a bit worried uk customs may start and wonder why Iāve received 8 knives this month alone Iāll be devastated if anything gets stopped oh god I bloody hate this country no joke lads i wished I was over there with yous
On a slightly different note, my main gripe with the Natchez isnāt the steel actually. Itās the cable tang. It just doesnāt inspire confidence for me. Iād rather they went with a full tang or even rat tail tang, both of which are proven designs for hard use knives.What do you want to be able to do with it ?
Probably be fine as a wall hanger , SD , even some light chopping .
IMO , it's a great fighter design , but was never really intended as a utility / bushcraft / survival knife .
The cable tang is actually an expensive feature , designed to mitigate shock , if the knife contacts hard objects like opposing weapons .On a slightly different note, my main gripe with the Natchez isnāt the steel actually. Itās the cable tang. It just doesnāt inspire confidence for me. Iād rather they went with a full tang or even rat tail tang, both of which are proven designs for hard use knives.
But yeah, as a wall hanger, itās okay I suppose. But Iām not a completely sane knife collector and I want to be able to whack my knives if needed.
It would be like owning a Ferrari, but you only get a top speed of 15 mph. Just why?
To be fair, I donāt own any cable tang knives so take my gum flapping on this topic with a grain of salt.The cable tang is actually an expensive feature , designed to mitigate shock , if the knife contacts hard objects like opposing weapons .
This is a meant to be a fighting bowie vs the Trail Master types , more bushcraft use .
yeah the whole cable tang is confusing to me. I've seen Lynn tlak about it costs more to do and isn't a cheaper way etc. also works better for that fighting knife....and such.To be fair, I donāt own any cable tang knives so take my gum flapping on this topic with a grain of salt.
Even for a fighting knife, wouldnāt a more conventional tang be more reliable? The last thing you want while fighting Decepticons is for the cable to fail and send yer blade flying from the handle. I think thatās less likely to happen with a full tang fighter.
The cable tang is a well proven, old technique to do two important things: mitigate shock asDocJD stated, and change the balance from the handle to the blade. The Natchez is a fighting design. Cold Steel seemed to market it as a fighter and a field knife, and I guess that was to sell more, but it was a mistake. The cable tang complaint is all over the internet and a black eye for the knife. not because its a poor design, but because it is a very specialized feature.
To make a comparison, it would be like a manufacturer making a match 1911 with extremely tight tolerances, and marketing it for matches and combat use. These pistols exist and are only good for target shooting. A combat pistol must have the tolerance for some crap, carbon, etc. to accumulate, but still function. A match pistol used in combat is likely to be unreliable because it has no "slack" built into the tolerances. The Natchez is the same way. It's not a chopper, though it may work as one for a while. The cable tang is a costly design feature, long proven to help when built into a fighting knife.
The Trail Master is Cold Steel's big woods bowie. Notice the TM doesn't have a tang, being full length from top to bottom. People complain about this too. That steel was there and Cold Steel paid people to mill that steel away. Why? Because if they had not, the knife would suck as a chopper, having too much weight in the handle and not enough weight forward to help with the momentum of the down swing. Milling the tang steel away cost money, but, just like the cable tang, it improves function. The best way to do this on a chopper is actually a tapered tang, but that cost quite a bit more, since milling machines prefer to make straight cuts. If Cold Steel had used a tapered tang, it would also be much easier to rehandled the TM!
I can appreciate the match 1911 analogy, thanks for the writeup. I myself prefer a non-match grade ādumbā 1911. Iām glad the Natchez exists for the collectors who want to have it then. Different strokes and all that.The cable tang is a well proven, old technique to do two important things: mitigate shock asDocJD stated, and change the balance from the handle to the blade. The Natchez is a fighting design. Cold Steel seemed to market it as a fighter and a field knife, and I guess that was to sell more, but it was a mistake. The cable tang complaint is all over the internet and a black eye for the knife. not because its a poor design, but because it is a very specialized feature.
I agree that it is wise to understand what any given knife is designed and intended to be used for .I can appreciate the match 1911 analogy, thanks for the writeup. I myself prefer a non-match grade ādumbā 1911. Iām glad the Natchez exists for the collectors who want to have it then. Different strokes and all that.
I guess from my perspective, I want a big field knife that can also serve as a fighting knife in extremely dire circumstances. The TM you mentioned with its more conventional tang would inspire more confidence. Or even the far cheaper SRK.
A āpure fighting knifeā that isnāt considered tough enough for big knife things not related to Jim Bowie duels aināt for me.
I don't believe that the cable tang bowies are fragile , per se , but are not optimal for anything that can put extreme abuse on the handle area .
You can use a sword for machete work, in an emergency ; but , it is a kind of a waste of a more refined /specialized tool .![]()
And would probably do just fine , in a fight , given the skills to use it !As we discuss the virtues of the Natchez Bowie, let's all remember that the knife Jim Bowie used on the sand bar near Natchez looked more like this than anything else:
Evidently it worked just fine for Jim. I'd rather have a little more of a guard, and loaded pistol or two.And would probably do just fine , in a fight , given the skills to use it !![]()
When you have a knife duel at high noon but itās also sushi night.As we discuss the virtues of the Natchez Bowie, let's all remember that the knife Jim Bowie used on the sand bar near Natchez looked more like this than anything else:
Reminds of a Jim Crowell knife I saw in a knife or gun rag - or could have been one of the annuals like Guns Digest etc - back in the 70s or 80s. Man I wanted one, but the cost prospect was too high for me at the time. But fantastic blade profile. Many butchers' knives are similar but the blades too thin.As we discuss the virtues of the Natchez Bowie, let's all remember that the knife Jim Bowie used on the sand bar near Natchez looked more like this than anything else:
