benchrest308
- Mar 13, 2014
Same issueNathan, DLC isn’t recommended for 3V because you have to heat the steel up to 450-500 degrees to apply it and it can mess up the HT. What about AEBL?
Nathan the Machinist would you be willing to look at Z wear? I'm curious to hear your thoughts about it as compared to Cruwear and if it may be a better candidate for tinkering with.
Hmmm... any possibility of having a batch of the preorder DEK1s sent off for DLC coating before they get sent to Pete's?Same issue
Would that work?Hmmm... any possibility of having a batch of the preorder DEK1s sent off for DLC coating before they get sent to Pete's?
Was asking you, lol. I don't know enough about the temperature resistance of DLC coatings or how they'd potentially be affected by the D3V heat treat process (or any effect the coating might have on the D3V heat treat process?).Would that work?
I know you’ve explained some of the differences before, but could you give us the strengths and weaknesses of the two steel offerings for the DEK? I intend to get one of each in tomorrow’s sale but this info may affect which blade I consider for which finish, assuming there will be the typical satin, stone washed and acid wash choices. When I read your previous post about it (not sure where that was at the moment) I felt like there wasn’t as much difference between the two as I would have thought just knowing one is “stainless” and the other is “semi-stainless.”
Nathan is there a fixed number of DEK's that you will take orders for tomorrow or is the pre-order open to all that want one and you will build as many as we order?
I'm not sure that I'll be able to post up at 5:00 EST because of work and boy do I want to get a "Gussied up" DEK.
Your grain is very fine Nathan. I hope you dint mind that I didnt call you back right away after that steak dinner I bought you.3V has extraordinarily good impact resistance and ductility at relatively high hardness and high abrasive wear resistance due to the high vanadium carbide volume fraction (one of the hardest carbides). The Delta protocol addresses its edge stability issues helping it achieve a durable edge at fine geometries making the steel both tough and strong in a knife edge application making the finished product an extremely useful highly durable cutting tool. Durable in both a large scale (the knife is practically unbreakable) and at a small scale (the edge will tolerate abuse without chipping or rolling). A side effect of the Delta protocol is improved corrosion resistance due to the free chromium making it nearly stainless.
Optimized AEBL is very tough for a stainless and has a fine edge stability almost as good as a simple carbon steel. It is very close to an old school simple steel (tough, easy to sharpen, takes a very keen edge) yet has good corrosion resistance. There are other more complex stainless with better corrosion resistance, but they're icky with that mushy crumbly edge that needs to be obtuse to keep from blunting when pressed into hard work. AEBL is a less expensive material than 3V and being a simple steel the heat treat process is a simple anneal, pre-quench, austenitize, cryo and tempers, which is less involved than the Delta protocol and more affordable. It's a good steel for non-knife-nuts because it is more adorable (edit affordable) and easy to maintain.
AEBL has good corrosion resistance compared to a carbon steel but it's not great compared to some other stainless, but this is necessary to retain its world class edge stability. Its edge retention is pretty good due to the high hardness, but it is not in the same league as Delta 3V because it doesn't have the abrasion resistance. It is easy to sharpen though and rewards a skilled sharpener with a fiendishly sharp edge with very little fuss. D3V can also get extremally sharp due to my fine grain, high hardness, uniform microstructure with minimal RA and other messy structures and 3V's ultra fine carbide, but it takes more time due to the resistance to abrasion.
Nathan , thank you for the DEK1 pre order. Any utility to ordering one with a swedge?
