Hi Nathan. I am stuck. And the bolt is stuck. I have pushed, pulled, and tried all sorts of chicanery to get this thing out. Any suggestions?
The one nearest the blade came out lickity split, the middle required a dithering, but I got it out, too.
Thank you.
I have done, and tried similar. I will continue this route. Thank you!I put a small punch in the hole and bear against the end of the screw and tap it out with a small hammer.
For sure. I actually reached out to Jo already because I really messed up the middle bolster. This final would is going to messed up, tooPut your wrench into the screw head and spin that barrel around as you’re trying to get it out. I’ve had some real hard ones also and a combo of spinning, pulling and tapping it out have worked. I’ve then taken some 800 grit paper to the spacer to smooth it back out (you’ll feel or see a little galling from forcing it out) and shine it up some, it’ll go back through easier.
After all, what could go wrong...put a small punch in the hole and bear against the end of the screw andtap it out with a small hammersmack the crap out of it with a bigger hammer
Nothing, you got a CPK!
Edit. Sorry thought I was in random
If at first you don't succeed, get a bigger hammer.put a small punch in the hole and bear against the end of the screw andtap it out with a small hammersmack the crap out of it with a bigger hammer
Depends on your personal preference/situation.So just got a K18 in today and I kinda feel like a new dad and just want to make sure I’m doing things right and I guess this could be answered by anyone who has one but do you guys just store it in its sheath or what? How do you guys stow this thing away when not using it?
