benchrest308
- Mar 13, 2014
So, just remove everything that doesn't look like a dagger?Nathan the Machinist will Jo's integral be the dagger design you were thinking of or is it more of a UF/Boot dagger hybrid? Jo's integral was something like 20lbs of bar stock milled to approx. 3lbs, right?
What can I say...I am aDude, give the guy a break for at least one day!
I resemble thisLathe guys are crazy. They're just different
I've used a T-slot cutter to cut blocks to size then used live thread milling to thread a hole on the x axis then line up the flat jaw pickoff to the flats of the part on the R axis for cutoff. That's pretty cool.Just a basic two-axis lathe gets pretty wild when you're interpolating your X and treating the spindle like a c-axis and using a live tool to cut a hex etc. You ever done anything like that? I've seen it but I don't know how to program it.
I also think that there are some 9 axis mills too, (the fixture platen moves too) but I could be wrong.I think a lot of the Swiss machines that I have seen were nine axis. Never ran one but I think it's basically like trying to program two different lathes. You're not interpolating all nine
Do you know what it means if the lathe guy is drooling out of both sides of his mouth?
His chair is level
*Grin*
Ugh, machinist humor, how……..boring.Do you know what it means if the lathe guy is drooling out of both sides of his mouth?
His chair is level
*Grin*
Even I get that one.Adding this one to my Dad-a-base:
Did you hear about the guy that applied for a job running a lathe?
They turned him down.
