Hey Nathan,
I have a ā¦buddy⦠who has had a lot of health issues and is super concerned about mold, dander, and just about everything.
He read somewhere that some knives shouldnāt be used around fires due to⦠off-gassing(?) or something carcinogenic.
I told him that wasnāt real unless chinesium from alibaba.
Any thoughts on carcinogens from knives around heat/ food prep?
Thanks.
I certainly wouldn't be worried about out gassing from the steel. When you consider all the things that happen to steel during its creation and the construction of the knife, you'll see that there is nothing in your use or in your kitchen that comes close to the temperatures and pressures and environment it was exposed to before you got it. That would be like trying to squeeze water out of a piece of glass. Just because it was made of sand that came from the ocean doesn't mean you're ever going to squeeze water out of it. That's not going to happen.
There is perhaps some danger of outgassing from the handle material, depending on what that is. But I wouldn't think anything significantly toxic is going to out-gas from anything that someone would use for a handle but leaching could be a concern. I would not want scales made out of poison ivy wood for example...
I think the most significant concern would be the knife construction and contamination risk rather than the materials.
Generally speaking, in a commercial kitchen, the knives are built to be easily and effectively sanitized. An overmolded plastic handle is pretty easy to clean. And they are usually stainless steel which does not require any kind of substance to be applied to reduce corrosion. I certainly wouldn't want to eat after a knife that was coated with engine oil as a rust inhibitor, for example.
I would not be overly concerned with toxins or carcinogens coming out of a knife unless it is of a weird handle material or shoddy construction. I would be more concerned about sanitation issues.
A long time ago, some steel was given corrosion resistance by being buffed on, and mechanically plated with, black lead. That might not be a great material to use in the kitchen, but no modern kitchen knife is going to be coated with something that toxic.
I would stay away from anything with a teflon coating. Bare metal would be best.
