Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
YesHi,nathan,have any of the DEK2s shipped?
NoIs there going to be a leather sheath option for the Shivs on pre-order?
Nathan the Machinist are there any signature SDFK left?
Actually, yes. Chad is going to do them, but we need to wait until closer to time for specifics. Thanks!Is there going to be a leather sheath option for the Shivs on pre-order?
Does off-gassing from the user pose any significant threat to the knives?I certainly wouldn't be worried about out gassing from the steel. When you consider all the things that happen to steel during its creation and the construction of the knife, you'll see that there is nothing in your use or in your kitchen that comes close to the temperatures and pressures and environment it was exposed to before you got it. That would be like trying to squeeze water out of a piece of glass. Just because it was made of sand that came from the ocean doesn't mean you're ever going to squeeze water out of it. That's not going to happen.
There is perhaps some danger of outgassing from the handle material, depending on what that is. But I wouldn't think anything significantly toxic is going to out-gas from anything that someone would use for a handle but leaching could be a concern. I would not want scales made out of poison ivy wood for example...
I think the most significant concern would be the knife construction and contamination risk rather than the materials.
Generally speaking, in a commercial kitchen, the knives are built to be easily and effectively sanitized. An overmolded plastic handle is pretty easy to clean. And they are usually stainless steel which does not require any kind of substance to be applied to reduce corrosion. I certainly wouldn't want to eat after a knife that was coated with engine oil as a rust inhibitor, for example.
I would not be overly concerned with toxins or carcinogens coming out of a knife unless it is of a weird handle material or shoddy construction. I would be more concerned about sanitation issues.
A long time ago, some steel was given corrosion resistance by being buffed on, and mechanically plated with, black lead. That might not be a great material to use in the kitchen, but no modern kitchen knife is going to be coated with something that toxic.
I would stay away from anything with a teflon coating. Bare metal would be best.
Now we have to be concerned about both poor heat treats and flatulence?Does off-gassing from the user pose any significant threat to the knives?
I mean, I'm pretty sure the gasses some people emit around here could be toxic enough to mess with the heat treat. Especially after chili night. I wonder if that's covered under the warrantyNow we have to be concerned about both poor heat treats and flatulence?
So, you'll have to work the edge until you create a burp on each side...
I think that CPKs can cut the mustard (gas).I mean, I'm pretty sure the gasses some people emit around here could be toxic enough to mess with the heat treat. Especially after chili night. I wonder if that's covered under the warranty![]()
Now you know what the “peppering” on the blades is really fromI mean, I'm pretty sure the gasses some people emit around here could be toxic enough to mess with the heat treat. Especially after chili night. I wonder if that's covered under the warranty![]()
That's right folks. Between everything and boogered handles, they may be considered Hazmat. Contact me for my address to safely dispose of your CPKs.Now you know what the “peppering” on the blades is really from![]()
They are knives that we have listed off and on since we started selling there. My intent to the change was so people can see we do sell on the site, but they are just not currently available. Bladeforums gets 1st dibs.Are the knives that have been listed on your site yesterday going to be standard offerings in the future or will they be limited runs to be replaced with new designs as they are developed?
Thanks
Damnit lolYes, but not very many.
