- Dec 11, 2022
#notnathanThanks for your response, Nathan, it makes a lot of sense. Now, knowing that your heat treat process takes your knives to the boiling point of Nitrogen, I am not concerned at all about exposure to extreme cold unless a knife is taken on a space walk. On the other extreme, high desert temperature, the recorded measured temperatures of various objects at high temperature desert sun exposure are all under 180 degrees Fahrenheit. (https://www.ncbi.nlm.nih.gov/pmc/articles/PMC10211493/ is one example). I bet those temps were measured at the center of the object. The sharp edge, however, could reach a higher temp but it is hard to imagine it will be over 200F. Will 200F do any damage to heat treat? Say someone uses his knife to boil his coffee at 212F and leaves the knife in the hot coffee pot for a while, will that damage the heat treat?
Nathan stated in his response, "My tempering temperatures are in the 400s. Stay below that and it's fine."
Your coffee temperature isn't going to hurt the blade, but I wouldn't be shocked if the coffee discolors it. Some people use coffee to discolor/patina steel deliberately. If that's not something you want, I wouldn't leave my blade in the coffee "for a while" if I were you.
