I know that isnt a lathe.
not like anything I've seen for turning. it looks more like a broaching tool. the work is held in the round thing and a sharp tool is pushed inside shearing out a precise amount and shape of material?
that's my guess. we broach a lot when we make set screws. the workpiece is held still and the cutter rotates.
that's how they do firearm barrel rifling so.etines too.
forging is better though imo
sorry I cant offer more help than that
Preorder on the 20th. It’s in the Next Sale threadIs there a ballpark for the khuk?
no chuck means no lathe. I'd have to get it in front of me to know exactly what's going on.Thanks for the input. What's really odd to me is the lack of a chuck or arbor, and even then, if the workpiece was piece was mounted in the spinning wheel, how could the lever push it through into the static blade? It would kind of render the fine blade adjustment moot, too.
It's possible that the lever side and the cutting side aren't even part of the same process. The large flat flywheel-like surface on the lever side looks like it's seen some friction action.
Hi Nathan, I have a question.
Do you know what this lathe-like object is or does? Its purpose? From the description:
"I purchased this beautiful machine at the estate sale of a machinist. I tried to find out exactly what it is, but couldn't get an ID from the forums. It appears to be a lathe of some sort. There is a wheel that spins, a space where something can get pushed in by a lever, and a metal blade that can be finely adjusted in and out of the opposite side of the hole where the lever is. The hole is 15mm wide."
the dial on the one side perplexes me..... I'm guessing it's for some kind of fi e adjustment of the workpiece?
it could be a full custom piece too.
let me know what you figure out please I'm interested
Pretty exquisite little piece of kit. I used to make trick stuff like that for the fiber optics industry up in Hickory near here.
My guess is it is some kind of an assembly tool.
It is using a tenths indicator for adjustment, so whatever it does is pretty precise.
Nathan, while at Bladeshow, was there any knife or item that caught your eye, and if so why?
Also, if you were tasked with grinding Wolverine’s claws, what would you do to make them as slicy or stabby as possibly considering your experience with blades?
Thank you.
Was it the handles that stood out to you?We did see and handle a few Loveless knives, and he has an outstanding reputation for good reason. Those were nice.
I didn't cut anything with them, obviously. But I could tell they would be good cutters.
It was the handle and the balance. They are light and thin and thoughtfully designed. It is a clean and elegant solution. No frills, just pure competency
Interesting
Was everyone allowed to hold them, or did they know who you are?
I've never held one, I really don't know If I'd like them, or not?
