Titanium Spacer, S30V for the blade. The grind is throwing me off, too - along with the old style clip. Some more pictures below;The 5/6 grind suggests it’s an F3R if an early model as the base model F3 has a full flat grind. You’re probably right that’s it’s an earlier F3 before they produced the two serial tiers. Does it have a titanium backspacer? What steel? Just curious, I have an F3R that looks just like it with M390 and is probably my favorite knife other than the room it takes up in the pocket
Yes my man. I got a F3NS in black carbon fiber and love it!Gonna be joining the club soon with a bronze f3ns![]()
I think it's an f3r. Someone can chime in, but they had "R" designations throughout generational design changes, correct?Titanium Spacer, S30V for the blade. The grind is throwing me off, too - along with the old style clip. Some more pictures below;
Photos
My take is it's definitely not an F3R. The only time I've seen the R (for Renewed) designation used is on the change of the two F series--F3 and F95--as well as the Hati back in 2017. On the F series knives, the new features included the change to MRBS, adding steel underlay washers to the pivots, redesigning the pocket clip, and milling out weight reducing pockets on the slab interiors. At the time these Renewed models were introduced they were also considered to be in the Three Bears category. Interestingly, the F95T Turtle never used the R designation despite Shiro considering it Renewed.I think it's an f3r. Someone can chime in, but they had "R" designations throughout generational design changes, correct?
I looked atPompous 's two sets of pics at Imgur and at his box label. Other than the blade grind, his knife bears all the hallmarks of the older version of the F3. If his knife was indeed an R it would be designated F3R on the box, which it is not. I don't believe there have ever been any SRBS or S30V R series knives made. The box label does indicate a separate FS, which is Shiro's code for 5/6ths blade grind with jimping. I had always thought that the 5/6ths grind originated on serial knives with the advent of the R series, but since that time I have seen more than one older serial knife with that grind and jimping. In the past there was more variation in features from one run of knives to the next within each model category including different steels, blade grinds, and jimping.
Regardless, Pompous's knife is very sweet and, while probably not unique, is at least quite unusual. Nice pickup there, P.![]()
The Zero has a titanium backspacer, M390 blade steel with a 5/6 grind (a small flat section just between the jimping and the primary grind) and full titanium handle scales whereas the NL has a stand-off and three bars to protect the tip from catching when closed, Elmax steel with a full flat grind and Micarta inlays. Both have MRBS.I’ve been really enjoying the F3 micarta. What a great tool! I’m thinking that it’s a bit bulky for summer shorts carry, which had me looking at the Neon as a potential addition to the lineup.
Can someone here help me understand the difference between a Neon Zero and the Neon NL (other than the $150 price difference)?
Thanks in advance!
Thanks, I can see the difference in the backspacer/standoff now. As well as the 5/6 vs full flat grind. Are the full Ti and micarta inlay scales roughly the same thickness?The Zero has a titanium backspacer, M390 blade steel with a 5/6 grind (a small flat section just between the jimping and the primary grind) and full titanium handle scales whereas the NL has a stand-off and three bars to protect the tip from catching when closed, Elmax steel with a full flat grind and Micarta inlays. Both have MRBS.
Tiers from basic to elite, of course, at the level of Shirogorov even basic models are done extremely well.Would one of you Shiro heads,ChazzyP ,
Mr.sig239 ,
Chuck_Nunface , etc please explain the hierarchy of Shirogorov knives, from top to bottom?
I know a little, but I don’t know a lot.
Thanks in advance.
Adamas , it's really not uncommon for a new knife, even a high quality piece like a Shiro, to have a little tactile or audible lockbar release when closing. A brand new interface will require a little while to wear in the spot where it locks up. It most likely will begin to feel freer as it breaks in, but even if there's just a taste of a click left when releasing that just means the knife is locked up securely.
All good now!Give it a couple days, you should be fine. With the F3, its a little tough to clean the lock bar face, but wipe off the part of the tang that interfaces with the lock face to clear off any oil that might be left on there form the factory. Might help.
I have been very tempted on both f these recent F95r drops...I may not be so strong next time.Well, I wasn't in the market for a new Shirogorov since I've already got more than enough. Truth be told, I've got too many already. But, this thing showed up at R-1 and being a sucker for green, I said happy Father's Day to me.I'm sure my kids will be happy for the gift they unknowingly got me.
