trevitrace
- Jul 21, 2013
Second this.Did you make two of the exact same threads.
[/URL][/IMG]![]()
My goodness, Ulf, how much of that poor tree did you punch through?
[/URL][/IMG]![]()
That's a really tough call, to tell the truth.
They both have great ergonomics, and feel good in the hand when cutting forcefully into material.
The tip on the 0561 is better for "tip work" as the Tuff has a very, VERY stout tip. Neither would break, but the Tuff is almost too robust at the tip.
Both steels are good, but if you want corrosion resistance, the 0561 is the way to go.
If you want "I can cross-grain baton to make notches all day" toughness, both will do, but CPM3V should be even tougher.
The flipper works very well on the 0561, and is the only flipper so far that I actually like.
However, I generally prefer the hole opener system; if you prefer flippers or holes, that could be the deciding factor.
I go back and forth all the time as to which I like better. I'd pretty much call it a tie, with the ZT getting more pocket-time right now due to being my newest knife.
The main deciding between them points based on preference might be:
-Flipper versus hole
-Stainless versus not-quite stainless (do you mind oiling the blade?)
-Lock stiffness on closing (the Tuff is harder to disengage the lock-bar)
-Choils...do you like them or not? Will you miss the little bit of extra cutting edge?
I think it must come down to those little personal preferences, because they are both so perfectly executed.
The only other point would be made in USA versus made in Taiwan: I'm cool either way, but for some that is a factor.
Today I like the ZT more.
Tomorrow it might be the Tuff.![]()
My goodness, Ulf, how much of that poor tree did you punch through?![]()
You could wait a month and purchase the new EnZo Borka 90. It should be about $160ish dollars.
Lone Wolf Harsey T1. End of discussion. You're welcome.
Scott
PM Fkk, he can help. He is the resident hard use folder specialist.
I have the Adamas but would actually sooner recommend the ZT0200 for it's (in my opinion) better ergonomics. It's just more comfortable in hand
Hinderer XM-18 3.5" Spanto
CRK Sebenza 25
ZT 0561
in that order[/QUOTE
I might get a hinderer! Cheers mate!
Usually, I try to avoid self deference. When I humble myself to myself, I unleash and ego that cannot be easily restrained. Like Cthulhu, only scary.
As to the knife question, I would start with a Buck 110 and when you find things that it can not do, continue the search with a specific set of parameters.
I don't mean to be a smart ass, but i would direct you back to my first sentence.Have fun, enjoy the hunt!
[/URL][/IMG]![]()
Contego would get my vote. Strong and M4 blade steel.
Frank.
[/URL][/IMG]![]()
