khunt, I have that same 119. A 1980 model. It has a thick blade toward the edge. Just the way they were done. Try using a Norton India stone and mark the edge bevel use a black marker. Then give it a few passes and see if the angle is going all the way to the edge. The steel could be 440C, a steel that resists grinding. Good luck, DM
Great advice DM,
The worse thing is if the knife hasn't been broken in correctly in the first place in regarding to the old 440c like the instructions with the knife or HONEMASTER instructions tell you do. It can take you awhile to get it right, when the burr shows up an before you change the motion direction from circle to swiping the stone. I get allot of old ones that are not sharpened with the convex bevel grind an it looks like they put it through a kitchen sharpener or those new belt sharpeners a V-GRIND bevel.
sorry for the quality on the BUCK instructions I just chose to scan it.
Yes, that one model or year they came out like that. I rebeveled mine some and it cuts better. I need to knock off much more metal to make it a good cutter. But it takes time and I have others.Thanks, I'll give it a try. You are right on it having a thick edge. To me its a very interesting grind. Its my only 119 but I like it.
Wonderful collection, Haebbie. What's the story on the 103 with the large finger choil? First photo, top knife.
