Guys,
Thanks for the input on the handles.
We will investigate.
Best Regards,
Paul Tsujimoto
V.P. of Engineering
Ontario Knife Company
Toooj,
Thanks for listening, and thanks for the reply.
(If Toooj is paying attention, it doesn't get better.)
I guess you could say that works both ways.
I would upgrade the design with a downward sweeping pommel to get a better backwards grip while chopping
I would certainly buy micarta grips also
I don’t own the smaller versions. Most if not all of my 4.5” and under blades are in stainless or d2. The vendor should have stated that the knife came with plain black sheath and no ferro.
The woodsman is about 9” of .25” thick 5160 steel with perfect heat treat.
My intent here is not to play the blame game, whether it be the vendor or Ontario, concerning what was advertised and what was actually sent. However it is never good when a customer is shipped something different than what was promissed. But I must ask why in the world did Ontario switch from the DeSantis sheath to the cheaper quality Chinese made sheath?
Also the description from the vendor in the above post is a little wonky as it is unclear that it is for the Utility or Field knife. But checking several other vendors all descriptions included the ferro rod, striker, lanyard, and DeSantis sheath for both the Field and Utility models.
I have no problem with 5160 being used on the shorter blades. I have over a dozen and a half knives made with 5160 from other makers and they have all performed to my expectations. And for whatever it is worth, my collection, if you want to call it that, is well over 300+ fixed blade knives and is comprised of just about every steel out there.
The Ontario Bushcraft series has been on my radar since they were first introduced. I contemplated between getting the 5" Field knife and the 4" Utility knife. Considering I have many knives in the 5" range and have been gravitating toward shorter blades, I opted for the Utility knife.
A description of the Ontario Utility knife is shown below.
"Ontario Bushcraft Utility Fixed Blade Knife 4" Clip Point 5160 Carbon Steel Blade Walnut Handle
Features
The OKC Bushcraft Knife was hand-crafted to give bushcrafters everything they demand in a survival blade. The blade is five inches of 5160 steel with a high, off center point. The flat-ground design allows for an increased cutting surface and a fine wood carving and meat cutting ability. Featuring a sheath by renowned holster manufacturer DeSantis, an American Walnut hardwood handle, a paracord lanyard and a fire-starter with striker, the Buschcraft Field Knife is an entire survival system."
- Paracord lanyard
- Fire starter with striker
- DeSantis sheath
- Flat ground blade
- Full tang construction
A photo of the Ontario Utility knife and contents as shipped from the vendor.
The good:
The fit and finish on the knife is very good. The grind was very good with even and uniform grind lines. The overall quality of of materials seemed to be OK.
The bad:
The first thing I noticed upon opening the box was the ferro rod, striker, and lanyard were not included as advertised by the vendor. Also a black Chinese made sheath was sent as opposed to the tan DeSantis sheath.
The knife is very handle heavy and uncomfortable for me. I get the impression the design was an after thought of shortening the blade of the Field knife while not shortening the handle on the Utility knife. The knife might work for someone else, it definitely doesn't work for me. The knife will be returned to the vendor for a refund.
Overall I am underwhelmed with the Ontario Utility knife. I don't recommend it. And I doubt if I would buy another one in the Bushcraft series.
Below are two photo comparing the size of the Utility knife to some other Ontario knives.
From top to bottom; RAT5, RAK, TAK-1, Utility, RAT3.
From top to bottom; RAT5, RAK, SK-5, TAK-1, Utility, RAT1, RAT3. And a carbon fiber D2 RAT1 on the side.
Is that RAT 5 a metric number RAT 5 in the picture there?![]()
