Roger
Chucks on the right track..
IG did that while I was at the last Hammer-in too
you'll have to use wood or what have you, to
supply enough fuel burning time for the time in the Oven.
Ig used 2 blocks of wood I believe. the paper in a sealed
pouch just burns out the Oxygen in the sealed pack,
well you get the picture.
on the alum plates you could adjustable hinge it
adjust it before you threat it, of course your more worried about
the taper other than the ricasso and the tang. would that solve your problem?
edited to add you could spring load it at one end
and put the point right at the end of the plates.
I'm thinking of a lot of ways you could do it...
edited to add again..
now I'm thinking you could kill two birds with one stone.
take the Oxygen out of the oven,,
I was thinking argon BUT this is being done now..
it's cold going in, slowing recovery time, and the cost is a concern.....
I'm going to try propane ( just enough to burn out the Oxygen),,
introduce it into the ele oven in flame.
Danger is if it goes out and builds up Boom !!..so it will need a constant ignition
even thought the oven will be red hot..
another problem I'm told of is, carbon dioxide is bad for the
elements in the ele oven just what I've been told ..
